Batts for tinny
Submitted: Saturday, Mar 25, 2006 at 12:43
ThreadID: 32144 Views:2550 Replies:2 FollowUps:3
Question for those who carry on roof or c/trailer a tinny and use an electric start o/board ,"what size and type of battery do you use ?" Where in boat is best spot for mounting same , ,,12ft clark cutter,10hp Mariner 2stroke.
Reply By: Member - Norm C (QLD) - Saturday, Mar 25, 2006 at 13:14
Can't answer all your questions, but an AGM is the go. I have used one for a while to run the elec motor on our canoe. Benefit is you won't spill acid when moving and carrying. If you need to, you can carry and use it on it's side. This is how I use in the canoe, shoved part way under the rear seat. And it holds it's charge well. If not used for several weeks, it will sill be charged when you need it.
AnswerID: 162807
Follow Up By: Alloy c/t - Saturday, Mar 25, 2006 at 13:20
Thanks for the reply Norm ,I am well versed in AGMs ,I run 5 of Fullriver 80 amper,s in vehicle and c/t ,what i need to know is what size for my outboard 2stroke motor with electric start.
FollowupID: 417560
Reply By: blackmax11 - Saturday, Mar 25, 2006 at 13:31
An AGM battery is theway to go. Suggest you get a plastic battery box (most marine dealers them) and battery terminals with wing nut connectors. Need to work out a way to sucure the battery box when boating (bit of a pain in a open tinnie). Battery in box is the easy and safest way to carry in car when not boating.
Also your 10hp only needs a small battery 35/40 ampere hour, if you have the rectifier charging kit fitted to your motor.
The engine you have is the easiest pull starting 10hp on the market. If you are physically capable I would just use as a pull start. Save heaps of drama when travelling.
If you need the battery for nav lights you can get around this, there are tourch type red/green navlights and white rear ones for not much money available.
Stay dry.
AnswerID: 162815
Follow Up By: Alloy c/t - Saturday, Mar 25, 2006 at 15:41
Nice ,but still does not answer the question.
FollowupID: 417577
Follow Up By: blackmax11 - Monday, Mar 27, 2006 at 20:11
I suggested the battery size, as for where to mount, to rear of boat in middle near transom. As for make of battery any quality battery brand.
FollowupID: 417989
