2001 Jyaco dove.
Submitted: Sunday, Mar 26, 2006 at 16:31
rickwagupatrol
hiya guys, just wondering if anybody can help me.
the wheel bearings on thedove are a bit loose, and as i suspect they may be a few years old now, i want to replace them. are they just a standard set of trailers bearings or some other size? any help appreciated.
thanks.
rick.
Reply By: Member JD- Sunday, Mar 26, 2006 at 17:10
Hi Rick,
If your able take the wheel off..hub..lightly tap out old bearing,there size and number should be stamped into the shoulder of the bearing..or take the old ones with you when you get the new ones.Hopes this helps.
JD
162981
Reply By: Michael ( Moss Vale NSW) - Sunday, Mar 26, 2006 at 19:43
Just to add to JD's comments. Dont buy cheap unbranded bearing from Supercheap etc. Better to get good quality bearings from a bearing outlet. I guess it is one item you would not need to let you down. Michael
163014
Reply By: Penguin (NSW) - Monday, Mar 27, 2006 at 08:33
Rick
I've just looked at my spare set for the
Penguin. It's an Outback so there may be a difference but
mine are as follows:
Inner
Bearing LM 12749
Shell LM 12710
Outer
Bearing LM 68149
Shell LM 68110
Those are NSK part numbers so any bearing
shop should be able to help.
Mike
163088
Reply By: rickwagupatrol - Tuesday, Mar 28, 2006 at 22:16
Thanks guys, got some today and all is again happy in the wheel bearing world...lol
rick.
163552
