Site Search
Section Image
antenna
Submitted: Monday, Feb 03, 2003 at 21:24
I am looking for advise on a antenna for a GME tx 4400 for
outback travel.
ThreadID: 3220 Replies: 4
Views: 850 FollowUps: None
AnswerID: 12459   Submitted: Monday, Feb 03, 2003 at 23:35
Wayne replied:
Check out Prestige Communications website and yoou'll find heaps of info on UHF's. They are located in Perth, but will post anywhere in Australia for a small sum (around $5 - $10)
Prices here are really good compared to other places that you can find on the net. Give them a call. They are really helpful.
Wayne
Reply 1 of 4
AnswerID: 12479   Submitted: Tuesday, Feb 04, 2003 at 13:36
Marty and Sam replied:
I am getting a TX3400 fitted on Friday by outbacker and they advised me to fit a GME AE409L ariel it is a 6DB to 9DB. It is a spring steel one that comes in two pieces so when you are around town you can use it as a 6DB then when you go bush you just screw the other piece on and it is a 9DB. I spoke to the guys at opposite lock and that is what they run on their vehicles and they have not broken one yet.
Reply 2 of 4
AnswerID: 12480   Submitted: Tuesday, Feb 04, 2003 at 14:01
Dion replied:
Dave,
not the cheapest option, but for quality and versatility, the GME 4700 series is good value. However really only suitable for bullbar mounting.
I use a 4705 antenna and base. Into that I can also use the larger 4706 antenna, but it does tend to lay back a bit at 110km/h, but good for slow desert work. You can also use all the smaller antenna's in the 4700 range, and you can use the AE409L antenna on the 4705/6 base.
I use this configuration for when I go shooting I can replace the big whita antenna's with the 409 in 6db set up which creates less of a target for wayward bullets.
Dion.
Reply 3 of 4
AnswerID: 12573   Submitted: Wednesday, Feb 05, 2003 at 19:17
DesF replied:
Hi. Dave I have a TX4000 With a AE409L, have had it about 8 years & it is still going strong Has done the Simpson , Googs & the Border fence etc I have found that the 6dB gives the best range unless it is very flat. It was explained to me that the 9 dB is like high beam ,long and narrow & the 6 dB spreads out more like low beam, also being thin you don't even notice it in the front. Cheers "D"
Reply 4 of 4
Activities Index
Ayers Rock Harley Sunrise Ayers Rock Harley Sunrise
Alice Springs and Central Australia - NT
Be a passenger on a legendary Harley Davidson to see an unforgettable sunrise over Uluru.
Full Day Trike Tour and Historic Train Ride for 2 Full Day Trike Tour and Historic Train Ride f
Sunshine Coast - QLD
This trip has it all - a fun ride on a custom built trike as well as a rollicking journey on a wonde
Skydiving - Accelerated Freefall Skydiving - Accelerated Freefall
The Heartlands - WA
The Accelerated Free fall from 14,000ft is your first skydiving experience.
Surfing Lessons x 2 - NSW Surfing Lessons x 2 - NSW
Sydney - NSW
Learn to surf with Sydney''s largest and most talked about surf school led by surfing legend Matt G
Book Now - Things To Do
