Gearbox oil?
Submitted: Friday, Mar 31, 2006 at 15:12
ThreadID: 32384 Views:2245 Replies:7 FollowUps:3
Greetings
It appears that our warm weather is over and I've noticed that with the cooler mornings, it is difficult to get the gearbox into 2nd gear. This was occuring last winter as well but went away during the summer months. I've got an 03 Patrol 4.2 td. When I bought the vehicle early last year, I had Nissan replace all the fluids. My thoughts are that the gearbox oil may not be the right grade or there is abetter grade to use. Has anyone experienced this problem and will a variation of oil grade fix it?
I've done a quick search and I didn't see anything specific.
Bart
Reply By: ro-dah-o (WA) - Friday, Mar 31, 2006 at 15:35
Yeah, have had the same and came down to putting a slightly thinner oil in the box. Worked a treat from then on in.
check your local gear box specialist, they will be able to tell you what you can put in.
AnswerID: 164091
Reply By: Member - Paul P (Bris) - Friday, Mar 31, 2006 at 16:35
Bart
My suggestion is to use a full synthetic oil. Use factory recommended viscosity. Should fix the problem and improve the shifting no end.
Paul
AnswerID: 164108
Reply By: Wayne (NSW) - Friday, Mar 31, 2006 at 17:07
Bart,
I would have to agree with Paul.
I had a similar problem with the 80Series and the synthetic oil fix the problem.
The other way is to do what I am doing with the Troopie and that is to go north west this winter . Saves changing the gearbox oil.
Wayne
AnswerID: 164115
Follow Up By: Bartz4b - Friday, Mar 31, 2006 at 17:17
Wayne
That's exactly what we're doing this year but unfortunately we have to come back!
Bart
FollowupID: 418981
Reply By: Member - Ed. C.- Friday, Mar 31, 2006 at 17:20
G'day Bart,
I was having similar problems 'till I woke up to what was the cause... I was using a
GL-5 oil.....
The recommended oil for that g'box is 75w-90 API GL-4....
I'm now using F u c h 's Titan Gear7590 (claimed to be semi-synthetic),
which covers GL-4 & GL-5, and I now have NO 'cold-shift baulk' problems, ever....
Whatever you use, make sure it meets the GL-4 specification....
Regards, Ed. C.
Confucius say.....
AnswerID: 164117
Follow Up By: Bartz4b - Friday, Mar 31, 2006 at 17:51
Thanks Ed. C.
I wonder what Nissan use?
FollowupID: 418990
Follow Up By: Member - Ed. C.- Friday, Mar 31, 2006 at 18:04
Dunno... probably whatever they can get at the cheapest bulk price;-))
My local dealership was carrying Castrol oils (in the spare parts dept.) at one stage, but lately, when I've been in there buying spare parts, I've noticed that they have
F u c h s oils on the shelf, so maybe they reached the same conclusion I did:-))
Confucius say.....
FollowupID: 418993
Reply By: rash - Friday, Mar 31, 2006 at 19:24
Mobil fully synthetic gear oil.........put it in gearbox,transfer case and diffs....will outlast the vehicle
Rash
I also use delvac mobil 1 engine oil fully synthetic .........change oil when oil test indicates
AnswerID: 164134
Reply By: Member - Phil G (SA) - Friday, Mar 31, 2006 at 20:44
Don't know about the Nissans, but the LandCruisers change well with
Castrol VMX-M 75/85 and Valvoline Duragear 75/85.
Theres a couple of others as well, but you don't need to go to a full synthetic gear oil.
AnswerID: 164158
Reply By: warthog - Saturday, Apr 01, 2006 at 09:42
I had the same problem with our GU and was recommended to try syntrax. This is a GL5 oil though its additives are not harmful to your syncro rings. It has proved to be much better than the mineral oils I have tried. I got some from a local truck repair work shop as I think it doesn't come in less than 20 ltrs.
AnswerID: 164222
