Nissan Navara 05 front end klunk
Submitted: Friday, Mar 31, 2006 at 16:55
kimbee
Hi there, the mighty Nissan has a front end klunk whitch happens when taking off in 1st gear and somtimes in 2nd, also when cornering to the left. I have looked hi and low checking every nut and bolt, sounds as if somthing is loose , wishbone or shock, but all checks out, is any body familiar withthis problem as its gettind louder.
cheers BB.
Reply By: Member - TonyG (Qld) - Friday, Mar 31, 2006 at 17:36
Hi Kimbe
I have had 3 navara dual cabs, some 2wd and 4wd.
All of them have had a klunk in
suspension when on hard lock, either turning left or right.
My current ST-R does the same.
If you figure it out, please let me know as it is annoying
Tony
164121
Follow Up By: kimbee - Friday, Mar 31, 2006 at 17:56
Hi Tony this particular noise is not at full lock, more so on take off 1st and 2nd but only some times. its driving me mad, we are of down south this weekend so Iam sure Iwill find out one way or another.
cheers BB
418992
Follow Up By: Member - Bill S (NSW) - Friday, Mar 31, 2006 at 18:51
tONY G, mate grease your sreering stops and the klunk will stop on full lock.
Regards BILLS
418999
Follow Up By: kimbee - Friday, Mar 31, 2006 at 19:09
Yo Bill quiet as a church mouse on full lock. NEXT
CHEERS BB.
419006
Reply By: kev.h - Friday, Mar 31, 2006 at 20:44
Hi Kimbee
Have had a noise before which turned out to be the left auto hub not releasing took awhile to find worth a look
Regards Kev
164159
Follow Up By: kimbee - Saturday, Apr 01, 2006 at 14:38
good try Kev, but but on investigation its not the hub.
thanks BB.
419134
Reply By: time waster - Saturday, Apr 01, 2006 at 07:26
Hi Kimbee, it could be a broken engine mount.
164201
Follow Up By: kimbee - Saturday, Apr 01, 2006 at 14:40
NO SIR REE MR TIME WASTER NOT THAT EITHER.
THANKS BB.
419136
Reply By: Member - TPM (SA) - Friday, Apr 07, 2006 at 21:56
Found this on the Pathfinder website, the chassis and
suspension on the R51 Pathfinder is the same as the Navara
Found by Nissan on this chaps vehicle after complaining of the noise.
May be worth checking out guys
pcoa.org.au/forumtemp/viewtopic.php?t=60
OK................... the verdict the knocking was a loose sway bar nut only 1/4 of a turn out of correct tension but causing a bloody big knock,
165686
