AnswerID: 167402 Submitted: Monday, Apr 17, 2006 at 19:15
Happy Little Camper
replied:
Hi All,
The 70L Downunder
fridge I found that did work on 12V in the store ended up failing 2 days into our Easter camp. It started doing exactly that same as the others, so we had to use 240V through an inverter for a while, which wasn't very efficient.
I phoned Downunder and Mark, their sales rep, promptly phoned back with an explanation and a solution. He said they had a bad batch of panel fans and agreed to ship a replacement fan to Repco Coopers Plains. I picked this up and had it installed and it has worked perfect ever since.
The 80W Solar Panel and 80Ah AGM was just enough power to keep cold food cold during sunny days. We used it in it's freezer/
fridge mode. However, to cool food down, or to survive a couple of cloudy days, you would definitly need 2 x 80W minimum. I do not know if a second 80Ah would be needed, but I plan to do an extended and controlled test at home as soon as I can buy another 80w Panel. On a couple of occassions, I won't mention any names, milk was put in the freezer compartment (next to my Bundy) and froze, which put extra un-necessary drain on the solar system. So, my advice is to manage your fridge/freezer carefully so as not to waste power, i.e. if possible only put frozen food in the freezer and chilled food in the
fridge.
In summary, and despite the initial fan problem, I highly recommend the Downunder 70L and I'm very impressed with their prompt and proficient level of service.
Driv'n Ivan
Reply 11 of 11
