OziExplorer GPS reciver compatability
Submitted: Sunday, Apr 02, 2006 at 17:31
Member - Darren T (VIC)
Just a quick question, does anyone know if the GM270U+ Ultra CF Card GPS Receiver in the ExplorOz
shop is compatible with OziExplorer software?
I noticed in the configiration section in the Ozi software you can choose what brand of GPS you have, but does not guarantee the other brands of recievers will work.
Darren
Reply By: The Explorer - Sunday, Apr 02, 2006 at 17:56
Hello - I have no doubt it will work - I use Holux GM-270....works fine (with OziCE on Ipaq 2210 PDA). No reason for the GM-270U not to work. CF gps units just out put standard NMEA data string..which is all OziExplore needs for moving map use. In configuration (GPS section) of the PC version you dont need to specify brand.....just select "NMEA only" (if you plan on using CF card GPS via laptop for example). In CE version on PDA just select appropriate port from which NMEA data is coming from...CF card GPS should show up as CF_Card-Generic-DDEA in Configuration NMEA (GPS) section (
well it does for me - COM port 7).
164422
Follow Up By: Member - Darren T (VIC) - Sunday, Apr 02, 2006 at 18:13
Thanks for the info, have the Ozi CE on PDA with the Navman sleeve which works good, but have just bought a laptop and installed Ozi onto it. Just wanted to know if the CF reciever would work before ordering one.
Cheers.
419288
Reply By: Member - Doug T (QLD) - Sunday, Apr 02, 2006 at 19:29
Hi Darren
When i got my Garmin Quest with USB it was not listed so I went to the OziExplorer Web site and downloaded the the update and all is ok
164440
Reply By: Utemad - Monday, Apr 03, 2006 at 00:46
My Holux GM-270 Ultra works fine with both my PDA and laptop both running OziExplorer.
164505
