AnswerID: 164588 Submitted: Monday, Apr 03, 2006 at 17:27
Member - Oldplodder (QLD)
replied:
Not sure what it could be.
Just been through the glow plug circuit on the Pajero.
At a guess it could be the timer in the relay or the temperature sensor.
I found most of my problems came from bad/corroded connections in the control system. Had to replace a couple of connections.
Have you put a multi meter on the glow plug bus bar to see if current is actually being supplied when the light flashes on? Is it just in the light indicator circuit, short or something?
 Click Image to Enlarge |
| John C - aka Oldplodder
In touring mode, the way it should be. |
Reply 1 of 1
FollowupID: 419525 Submitted:
Monday, Apr 03, 2006 at 20:40
Ian D R F posted:
Thanks, I'll check all connections.
I've noticed today that with the revs up the light goes out. I'm wondering if the voltage regulator is a bit dicky. I'll check the bus bar as you suggest first.
