Battery problems - follow-up
Submitted: Monday, Apr 03, 2006 at 21:18
ThreadID: 32490 Views:2242 Replies:3 FollowUps:3
OK Guys I had my battery tested today and it is stuffed. It has dropped one cell.
Guess I need to get a new one, what would people recommend? I would like one that is capable of running a fridge etc for future use.
Keep the suggestions/recommendations coming.
Reply By: Derek from Affordable Batteries & Radiators - Monday, Apr 03, 2006 at 21:44
Agm's are the best battery at the moment.
Size could be a problem, is it going into a 4 runner.
AnswerID: 164631
Follow Up By: TerraFirma - Tuesday, Apr 04, 2006 at 14:19
Is it a case of AGM's being the best value or the best battery. I am hearing that Gel Batteries have some strong advantages over AGM, but are usually dearer..? I was at Batteryworld today and was intent on buying AGM's for a Big Boat application, however they advised me that the Gels would be better suited. Application was simply house electronics and some starting. I was told the Gel's are more suited to high cyclic applications.
FollowupID: 419644
Follow Up By: Derek from Affordable Batteries & Radiators - Tuesday, Apr 04, 2006 at 14:31
All depends on the charge rate and how far you discharge the unit.
Some gel batteries will not fast charge and can be damaged.
FollowupID: 419648
Reply By: Sparkiepete - Tuesday, Apr 04, 2006 at 05:47
I've always been a fan of Delkor Calcium batteries. For some reason my 4WD has never started better or as quick.
I am looking for one to put under my bonnet of the Jackaroo. The biggest I can fit is 80AH NZ770? About 300mm long and should run my Engel for about 24 hours sitting. $220.00 is the quoted price for this battery
Sparkiepete
AnswerID: 164656
Follow Up By: Russel & Mary - Tuesday, Apr 04, 2006 at 07:57
Are you talking about N70ZZ, if so they are only about $100. I run either two N70ZZ or N70EX ($85) , both 80ah and I'm happy. Rus
FollowupID: 419571
Reply By: Member - MrBitchi (QLD) - Tuesday, Apr 04, 2006 at 08:05
Exide Extreme.
AnswerID: 164671
