Seat belts
Submitted: Thursday, Apr 06, 2006 at 19:18
Bartz4b
Hi all
I'm having trouble with the
seat belt on my GU Patrol. It doesn't retract properly and often gets jambed in the door. If I don't fix it, I can see the paint getting chipped and I would prefer to avoid that. Is there an adjustment on the retracter spring? Is there something else that causes this problem?
Bart
Reply By: Trevor R (QLD) - Thursday, Apr 06, 2006 at 19:36
Bart,
I will be interested in the answers here as
mine does this on the front passengers side. I've never had the inclination to fix it as I always thought it would be too dear or too difficult to do. I hope someone can prove me wrong.
Cheers TRevor.
165352
Reply By: Member - TPM (SA) - Thursday, Apr 06, 2006 at 19:51
Hi Bartz4b
Not sure if you used the
forum search or not, there was a post a few weeks back on this same item, there was a few suggestions relating to it.
Good luck
165359
Follow Up By: Bartz4b - Friday, Apr 07, 2006 at 11:36
TPM
I couldn't find it on the search. Do you know the thread No.?
420411
Follow Up By: Member - TPM (SA) - Friday, Apr 07, 2006 at 16:53
They are still open , I just typed in ..seatbelt.. in the search
forum.
Post ID 31779 , 31858 , 32596
Hope that helps : )
420479
Follow Up By: Bartz4b - Friday, Apr 07, 2006 at 17:50
Thanks. That helped:)
Bart
420496
Reply By: Old Scalyback & denny - Thursday, Apr 06, 2006 at 20:34
evening all
no good asking the dealers as they are hopeless they had 3 goes at
mine( probably what they want but i gave up asking )
gave up using dealer when then couldnt replace the service sticker its still on the winscreen half scraped off
sorry back to the question i just try to remember to make sure i pull the slack in to coil up before exiting the car
steve
165377
Reply By: Willem - Thursday, Apr 06, 2006 at 21:18
Make a small hole in it and then hook a short Ockey Strap to it. It will retract every time till the Ockey gets weak. Then just replace the Ockey...LOL
My GQ does the same but I don't care......:o)
165398
Follow Up By: Member - TPM (SA) - Friday, Apr 07, 2006 at 00:20
Hi Willem,
Did you ever track down that elusive book ?
How was the trip away, no dramas I hope?
420316
Follow Up By: Willem - Friday, Apr 07, 2006 at 05:59
G'day TPM
Yes. There were copies in
Melbourne and
Adelaide but access was difficult. Rick(SA) managed to get some maps for me from books he found in
Adelaide.
We have not been on the trip yet. Leaving here on 22 April. Permit application is now 6 weeks of age and still no result.
420324
Reply By: Member - Graham G (VIC) - Friday, Apr 07, 2006 at 10:21
There is a fix for them under warranty. I had it done to
mine but it made no appreciable difference. I have now got into the habit of making sure
mine is fully retracted and shouting at the kids "SEATBELTS" every time they get out of the car. Not ideal but I'm getting weary of fighting everybody about everything all of the time!!! Sad I know
165526
Follow Up By: Bartz4b - Friday, Apr 07, 2006 at 11:44
Graham
Fortunately the drivers
seat belt is the only one that is causing problems at the moment. God help me when the kids
seat belts do the same thing. I'll probably tear out what little hair I have left.
I remember years ago someone suggested that the problem with the
seat belt is caused by dirt and grime in the actual belt. This apparently caused more friction as it got dirtier. I've also been told that a quick spray of silicone spray will fix the problem. Not sure about spraying the belt although I doubt that silicone spray would hurt it, just leaves a stain on your shirt when you put the belt on. I must try this remedy (on someone elses car first).
420413
Reply By: rolande- Sunday, Apr 09, 2006 at 21:22
G'Day All,
Sorry for lateness of reply, was sure I had posted to this before but the post has gone.
Anyhow, Patrol seatbelts work much better after they have had a wash.
I had the same "difficult to retract" problem and it was suggested to wash the belt.
I haver a little high pressure spray unit at home so used this, the ones at the car wash are also fine.
Extend seatbelt fully and place on outside of vehicle, then close door.
I carefully then sprayed the belt with
water only. You can notice the difference immediately, went from dark
grey to light brown. Just be careful with the spray that you do not damage the webbing in any way - no detergent!
Let the belt dry and hey presto - belt retracts much faster and neater
Hope this helps
Rolande
166048
