mosfet control box for warn
Submitted: Sunday, Apr 09, 2006 at 12:11
ThreadID: 32698 Views:3241 Replies:4 FollowUps:10
scannin with mate on 10k warns, anyone seen these?
Site Link
Anyone used one?
Reply By: Member - 'Lucy' - Sunday, Apr 09, 2006 at 12:59
Morning Truckie
If you and/or your mate have no problems with dishing out the $'s then go for it.
Haven't used one as the amount of times I use the winch, the controller it comes with does quite nicely.
Have spoken to guys at winch comps about these and have yet to see one using them.
However, at the Vic Winch last year there was a Comp truck with a English/Pommy version of this type of controller. (ie solid state).
Apparently half the price of a MOSFET.
Other than that can't help you much more.
However, having said the above will no doubt attract the 'Doom, Gloom and Dispair' addicts to have an input.
AnswerID: 165940
Reply By: Kiwi Ray - Sunday, Apr 09, 2006 at 13:35
Hi Truckster
Superwinch have had one out for about 18 months now, I have used their one in for competitions so far with out any problems. It is very compact and water proof
I know about the Warn model but have not seen one yet
Ray
AnswerID: 165944
Reply By: Mad Dog (Australia) - Sunday, Apr 09, 2006 at 14:08
I wouldn't mind one at all, any idea how much they are Bruce ?
AnswerID: 165946
Follow Up By: Mike Harding - Sunday, Apr 09, 2006 at 14:17
Expensive, I'll bet. Why not make one then you could include PWM speed control too? How much current does a winch pull under max load - 100A... 150A?? Might need to do a bit of load sharing on the MOSFETS but it wouldn't be too difficult.
otoh semiconductors do have a habbit of blowing up rather more readily than relays and would be more difficult to do a field repair on...?
Mike Harding
FollowupID: 420875
Follow Up By: Mad Dog (Australia) - Sunday, Apr 09, 2006 at 15:22
shreek, I probably could with your help :) but that sounds like work :)
FollowupID: 420882
Follow Up By: GaryInOz (Vic) - Sunday, Apr 09, 2006 at 16:43
"...otoh semiconductors do have a habbit of blowing up rather more readily than relays and would be more difficult to do a field repair on...? "
Not necessarily so...Which is more reliable and hassle free, a external solenoid type alternator regulator, or an internal electronic one?
Semiconductors blowing up is more likely to be because of poor design/poor environment (cooling)/"cost cutting" (specifying components that will only "just" do the job), than by any inherent defect in the semiconductor itself.
You are already using Mosfets in the output stages of your electronic ignitions, more often than not in your fuel injection drivers, and many other electronic bits in your car, and you "trust" them....
The failures will follow the usual "bathtub" curve (quite a few (relaively) initially, reducing to an insignificant number for a looong time, then a slow increase in failures) , but with a considerably longer time between failures (bottom of the bathtub curve) than would be the case with a solenoid type regulator.
As for doing a field repair, all that would be needed would be a soldering iron ($20 butane one would be fine), a multimeter,screwdrivers/spanners as appropriate, a spare Mosfet or two, and the knowledge to work out which one is dud. In other words, apart from the Mosfet, nothing over and above what you would normally have on hand in your tool box.
FollowupID: 420893
Follow Up By: Mike Harding - Sunday, Apr 09, 2006 at 17:02
Hi Gary
Welcome to the world of commercial electronic product design.
>As for doing a field repair…
An anti-static handling station?
I have a lot of kit out there right now in military situations using my MOSFET designs for high current 12V DC motors and they work pretty well, very few field failures over the past 6 years but they are well over-rated for the application and I could do that because the margins on military equipment are considerable - consumer stuff is a whole different ball game. If I had an electric winch I would stay with the relays, carry an extra one and be pretty sure I could, somehow, repair the contacts enough to work another time or two - I don't fancy my chances with repairing a shorted MOSFET.
Mike Harding
PS. I'm currently working on automotive electronics - I am surprised how often relays are still being used in new designs.
FollowupID: 420895
Follow Up By: warthog - Sunday, Apr 09, 2006 at 17:04
What does mosfet stand for?
FollowupID: 420896
Follow Up By: Mike Harding - Sunday, Apr 09, 2006 at 17:20
Metal Oxide Semiconductor Field Effect Transistor.
It's a modern-ish transistor used mainly for switching purposes - they can handle very high currents and are very fast in their switching which means they dissipate low power when switching high currents.
Mike Harding
FollowupID: 420900
Follow Up By: warthog - Sunday, Apr 09, 2006 at 17:35
Thanks Mike, as you may have gathered I know nothing about electronics/trickery but find stuff it can do intersesting.
FollowupID: 420902
Follow Up By: GaryInOz (Vic) - Monday, Apr 10, 2006 at 02:28
"...Welcome to the world of commercial electronic product design...."
More or less what I implied - "cost cutting" = bad design using parts that are sailing a bit too close to the wind ("under" or "at" rated). No argument there...
"...An anti-static handling station? ..."
Not needed, with adequate preparation. Most high current mosfets have (Gate - Source - Drain) internal protection diodes. If you are that worried, punch the Mosfet leads through aluminium foil before you store them or loop a strand of wire between all the terminals. During the installation, solder the leads with the aluminium foil in situ or leave the loop of wire intact untill all the connections are made, and remove the foil/wire when finished.
"... I don't fancy my chances with repairing a shorted MOSFET...."
As long as the intenals are not potted (unlikely due to req for free air circulation), there would be no reason why this could not be attempted. If you were really , really worried connect a bare wire round your wrist, looped around the butane torch or spanner (more likely given the currents concerned), and clipped to the metal casing of the Mosfet.
Could it be any worse than trying to repair a burn out contact or open cct coil? They are both going to leave you high and dry if you don't have spares. No difference in difficulty really, pretty much a choice of what you want to fix and how often/likely it is going to need a fix.
If you wanted to make a true antistatic station you could improvise one with an aluminium frying pan (workstation), a couple of tent pegs into wet earth (earth point) and a length of wire connecting them (and also to you and you tools as described above). Still nothing out of the ordinary extra you would have to take....
FollowupID: 421005
Follow Up By: GaryInOz (Vic) - Monday, Apr 10, 2006 at 02:36
One other thought is with the Mosfets you could just leave the offending one out of the cct assuming they were using >3-4 to do the switching per "contact". The switching cct would still work but would have less current capacity. The idea then would be to try to beeconomical with current drain/load on the winch by using the 1st or 2nd layer of winch cable rather than the 4th or5th layer, and use a snatch block at all times.
FollowupID: 421006
Follow Up By: Mike Harding - Monday, Apr 10, 2006 at 08:55
Hi Gary
Don’t you let a production engineer hear you say that! They’d confiscate your soldering iron :)
>attempted.
I actually meant the MOSFET itself rather than replacing it. With a relay you’re in with a fighting chance of repairing burned contacts – the most likely fault in this application.
In essence I agree with you that providing you have the skill, knowledge and tools to fault find electronic circuits it could be done at the roadside providing it was simply a MOSFET failure. The trouble is that the MOSFETs will be surrounded by a fair number of other components to handle gate drive, load sharing, overload protection etc and all these components will, almost certainly, be surface mount and if they’re 0603 you’ll be damn lucky to _see_ them let alone repair them with a gas soldering iron – not to mention you’d probably stuff the PCB tracks/pads in the process, in fact I note IR are now doing a surface mount MOSFET to handle 110A so even the MOSFETs may be surface mount. In fact in a paralleled MOSFET H bridge configuration finding which one had blown without de-soldering a number of them or cutting tracks would probably not be possible. Far easier to plug in or resolder 4 wires to a relay I reckon.
Mike Harding
PS. Dave, thanks for the 400A info, I didn’t know it was that much but I’m not surprised.
FollowupID: 421038
Reply By: geocacher (djcache) - Monday, Apr 10, 2006 at 05:35
Most Warn style winches are capable of pulling close to if not more than 400 Amps at full load (near stall).
AnswerID: 166084
