GPS Tracking over the Internet
Submitted: Friday, Apr 14, 2006 at 07:54
ThreadID: 32880 Views:3177 Replies:7 FollowUps:17
Hi Forumers :-)
A mate and myself are just about to head off into the Vic High Country next week from Sydney, we have done some of the High Country before and experienced with GPS. This time we are leaving the wives and kids at home smile.gif and I was thinking of trying something.
NOW is this possible/Doable?
Have the Friends/Family at home see where we are in realtime over the internet (broadband). We will be using a laptop with OziExplorer and 1:25k maps in the HighCountry to plot, track and record our course.
Even if there is a service you can subscribe to, Just looking at feasibility and options re this
All advice and suggestions appreciated
thanks.
Aaron
Reply By: Michael Carey - Friday, Apr 14, 2006 at 08:19
Yes it is possible with software called NetGPS. It's a "plugin" that works with Oziexplorer. It takes NMEA data from your GPS and sends it off (via whatever internet connection you have while mobile) to a small PERL script running on a web server where it stores your position against a username and password you set on your NetGPS. It also passes the GPS NMEA data to Oziexplorer running on your laptop. Setting up the NetGPS server can be the most difficult part, you really need some experience with PERL (or find someone that has!). I'm still trying to get it running on my web server without success. Best thing would be to find a NetGPS web server that someone else has set up and use that.
At home, NetGPS is set up to access the same NetGPS server (with the same username and password) and it responds with the last position received from the remote and plots it on Oziexplorer.
According to others, it works quite well. Check out details here :-
NetGPS
Hope this helps, or at least confuses you (-:
Regards,
Michael.
AnswerID: 166982
Follow Up By: Mad Dog (Australia) - Friday, Apr 14, 2006 at 10:23
Hmmm, just need to work on maintaining an internet connection while mobile in the High Country.
FollowupID: 421999
Follow Up By: Mike Harding - Friday, Apr 14, 2006 at 18:28
I did actually look at this Ray, using the CDMA Broad(ish) band system from Telstra but concluded that the coverage was so small and would be much worse in valleys that it wasn't worth $100 per month - $10 maybe?
To the OP:
If you're going to do this often consider the VKS737 4WD radio network or, even better, becoming an Amateur Radio operator which is pretty easy with the new Foundation Licence.
I may be wrong but it sounds as if you're not experienced with the High Country? It can be very unforgiving at any time but especially after rain or in winter. A UHF CB is not much use in this region unless you are on a hill top (limited, even then) and I would suggest that if you are going far from the major tracks and/or campsites you consider a better form of communications which means HF radio or Satellite Phone. Both are expensive options and if you don't want to spend the cash consider an EPIRB - about $250 from Dick Smith.
Mike Harding
FollowupID: 422046
Follow Up By: Mad Dog (Australia) - Friday, Apr 14, 2006 at 20:01
Mike, yep just what I expected regarding High Country coverage.
I think the foundation licence only allows voice operation so unfortunately no aprs.
FollowupID: 422071
Reply By: Member - Troll 81 (QLD) - Friday, Apr 14, 2006 at 08:28
Hi Aaron
I just did a search in google and found heaps of sites that does vehicle tracking so that might be a option to look into?
AnswerID: 166983
Reply By: Bob - Friday, Apr 14, 2006 at 08:51
Check this out, works with HF radio.
www.bcon.com.au
A new system with a lot of promise. Should be about ready to go.
AnswerID: 166986
Reply By: Member - Troll 81 (QLD) - Friday, Apr 14, 2006 at 10:14
Funny you asked this question when I got home I saw add on the TV over here in the US. They use your mobile phone to locate you...have a look maybe this will become available in Aus sometime soon
www2.sprint.com/mr/news_dtl.do?id=11280
AnswerID: 166990
Follow Up By: geocacher (djcache) - Saturday, Apr 15, 2006 at 04:44
Ha ha ha, LOL.
(Laughing sincerely at a funny thought, not at Troll's attempt to help.)
Every time I drive out of the Wonnangatta, Crooked River, Davies Plain or similar, at some point the phone beeps madly with all the messages from work asking me to come in and work on my days off. They try and "use my mobile to locate me too" - thank Christ it doesn't work - and no they can't have my Satphone number.
BCON will be good but there's the outlay on the Codan to use it. A 9323 or NGT will be needed and neither are cheap. Though they have lots of other uses.
DJ
FollowupID: 422110
Reply By: ExplorOz Team - David - Friday, Apr 14, 2006 at 11:35
Aaron,
Funny you should ask this question! Why because I am build an SMS to map family & friends system on ExplorOz at the moment. I have the database design completed and I am just evaluating the costs of setting up an in-bound SMS gateway - it appears these cost a few hundred to setup upto $500 and then around $50/month ++ to operate.
The new service will use the iMapPot engine and have your position and last message shown + show the past points and history for each trip that you can configure. So when you send in the SMS it will contain the following info
"Latitude" "Longitude" "Text message upto 100 chars"
e.g: -31.2123 115.4324 We are having a great time - no problems
When you SMS this to the number we will straight away plot it on a map and show the message. Additionally I will be writing an OziExplorer interface so that if you happen to have mobile broadband and be in a service area a live map position feed can be loaded to the Internet map without SMS. Also there will be a page you can enter a current position if you are say at an Internet cafe or similar.
Now we are working on the cost structures of this service and I think it will work out roughly like this:
Membership of ExplorOz required $30/yr (plus $20 joining)
Subscription to the SMS to Map System approx $120/yr or $20/mth
Dependant on the costs of the SMS gateway and the number of interested people these charges may have to change. We may also have a cost per SMS fee but this will be dependant on the gateway fees.
I have one person already who has made a commitment to use the system. Any other interested persons please let me know. As I said we are working on this right now so if interest is high I will push forward a little faster.
AnswerID: 166995
Follow Up By: Mike Harding - Friday, Apr 14, 2006 at 18:15
The obvious problem is that the places most of us go where family/friends may be worried about us are, invariably, not within mobile phone service areas - otherwise we could just call or SMS family directly.
And with CDMA being killed in a couple of years that situation will probably worsen?
Mike Harding
FollowupID: 422044
Follow Up By: Member - Davoe (Widgiemooltha) - Friday, Apr 14, 2006 at 20:47
AFAK Mike you can SMS with a sat phone
FollowupID: 422076
Follow Up By: geocacher (djcache) - Saturday, Apr 15, 2006 at 04:47
Only with some Davoe.
The Motorola 9505 can send & receive SMS. The 9500 is receive only. I don't know about the others but they use a combination of CDMA or satellite when no CDMA is available. I don't think I'd buy one now they're turning CDMA off.
FollowupID: 422111
Follow Up By: Member - Davoe (Widgiemooltha) - Saturday, Apr 15, 2006 at 06:13
Pretty sure the Tellits we were using at one stage could SMS
FollowupID: 422114
Reply By: hl - Friday, Apr 14, 2006 at 11:51
You can, but you need an Amateur Radio license.
Look up APRS in Googel and you will see lots of info.
Check this link, and you will see where I am.
Enter the call VK2HL-15 or VK2HL-9
This site can also give you a track over that last few days. It will do maps down to street level, even google earth. We use it exensively when we travel the outback and our relatives both here and overseas have a lot of fun tracking us.
www.jfindu.net/bystation.htm
AnswerID: 167001
Follow Up By: hl - Friday, Apr 14, 2006 at 12:00
or try this one:
Site Link
FollowupID: 422010
Follow Up By: Michael Carey - Friday, Apr 14, 2006 at 18:45
Another Amateur on APRS in the forum!!
Check out where I have been here :-
HF APRS track
Michael.
FollowupID: 422049
Follow Up By: Mad Dog (Australia) - Friday, Apr 14, 2006 at 19:32
I much prefer the Java maps at jfindu
jfindu
FollowupID: 422059
Follow Up By: Mad Dog (Australia) - Friday, Apr 14, 2006 at 19:35
right click to zoom in to street level
FollowupID: 422060
Follow Up By: Michael Carey - Friday, Apr 14, 2006 at 19:38
That's cool!!
FollowupID: 422063
Follow Up By: Mike Harding - Friday, Apr 14, 2006 at 19:45
You guys are just hung up on technology - sigh....
Mike Harding :)
PS. If I were married I'm not at all sure I would want vehicle tracking!
FollowupID: 422065
Follow Up By: Mad Dog (Australia) - Friday, Apr 14, 2006 at 19:46
sure is, track can be done also.
They put bluddy "STAGING" all over the maps now...arggg
FollowupID: 422066
Follow Up By: Mad Dog (Australia) - Friday, Apr 14, 2006 at 19:50
Mike
My children just love seeing where daddy is and I love knowning they are watching.
Yeah the missus looks also
FollowupID: 422069
Follow Up By: Mike Harding - Friday, Apr 14, 2006 at 19:59
Fair point Ray - and given the places we go there is not a lot one could "get up to" out there :)
Mike Harding
FollowupID: 422070
Reply By: Kiwi Kia - Friday, Apr 14, 2006 at 14:45
There is a lot happening in this area of technology at the moment and new systems are coming on line all the time. It will prob be very common in a years time. In many countries Police vehicles, diplomatic vehicles, politicians, armoured cash vehicles, petrol and other dangerous goods vehicles etc. etc. are fitted with 'on-line' tracking devices using the cell phone network to transmit data including speed, lights (blue / red), data back 'home'. Rental car companies also have a great interest in knowing where their vehicle is and how fast it is going !
Do a Google search on data loggers, I saw a 'covert' gps position logging and reporting device for public sale on there recently.
AnswerID: 167012
