Noise problem
Submitted: Saturday, Apr 15, 2006 at 13:23
ThreadID: 32913 Views:1633 Replies:3 FollowUps:1
I have a VY Commodore and it has started making a "weering" noise. I only notice it at low speeds and while turning. I thought it might be the power steering, but I have checked the fliud level and it seems OK, Plus the noise is not there while the car is stationary.
Any ideas.
Wato
Reply By: desert - Saturday, Apr 15, 2006 at 14:32
sounds like air in the steering system. Have somebody turn the wheel from side to side while you listen and locate the source.
AnswerID: 167134
Follow Up By: wato35 - Saturday, Apr 15, 2006 at 14:36
What will that tell me? Sorry I have very little mechanical knowledge.
FollowupID: 422179
Reply By: Member - Leigh (Vic) - Saturday, Apr 15, 2006 at 16:09
Check belt tension??
AnswerID: 167141
Reply By: Member No 1- Saturday, Apr 15, 2006 at 17:45
check your tyres for uneven wear at edges...run your hand (flat) same way as rotation and then back....note any difference....if so that is most likely the cause
AnswerID: 167143
