plastic taste from water tank
Submitted: Tuesday, Apr 18, 2006 at 22:06
Eza
Hi All
anyone got any tips for getting that new plastic taste out of a
water tank, have used food grade hose to fill the
tank but still tastes horrible to drink very plasticy
any ideas much appreciated
Reply By: Laura B - Tuesday, Apr 18, 2006 at 22:07
heard a few things...those tablets that you can buy that do something to the
water....but it tastes weird still....
major rinsing out with bi-carb.....
Laura B
167682
Follow Up By: Nick R - Tuesday, Apr 18, 2006 at 22:23
yep, go the bicarb
Nick
422890
Reply By: johannagoanna - Tuesday, Apr 18, 2006 at 23:34
Yep, Bicarb is great for this type of thing! I give
mine a rinse with bicarb after each outing, and have never had a problem with the taste of the
water. If it continues maybe give it a rinse with very weak Bleach, but give it a really good rinse out afterwards. - Jo
167703
Reply By: ev700 - Tuesday, Apr 18, 2006 at 23:38
Having been around caravans a whileI find that this question comes up often and is sometimes not solved by adding bicarb or other solutions.
Some people seem to be more sensitive to
water taste. Other point is that somewhere along the trail you will be picking up
water that may have an odd taste.
Best approach is to fit a
water filter (eg from Bunnings). Some have two filters: in and out.
EV700
167704
Reply By: Member - Paul P (Bris) - Wednesday, Apr 19, 2006 at 07:31
Greetings
Is your
water tank made of food grade plastic? If not this could be the problem.
Paul
167725
Reply By: Member - RockyOne - Wednesday, Apr 19, 2006 at 08:07
Martha Gardner would possibly say"Try a little bleach love..White King" She may also say " White vinegar..but rinse
well after either one,or the bleach may turn your red corpusels into whites" End of MG..Warning ! Put the white vinegar bottle back in the kitchen where it belongs..I did'nt..I was using it up in the shed to de-taste some
camping gear..Later,hot day,was looking for a drink,grabbed this square sort of one litre clear plastic bottle,big swig..YIKES !! Tasted like acid possibly does..Sprayed that out..Everywhere.Then (I repeat!) then,I read the label.."White vinegar" (I thought I had learned my lesson when,as a child,I drank kerosene (was white/clear in those days) in a bottle near the kero fridge.)!MPG:6!
167731
Reply By: Member - Phil G (SA) - Wednesday, Apr 19, 2006 at 08:48
I had that problem with
mine, but the
tank wasn't at fault. Problem was the hoses for the tap, filler and breathers. Replaced them all with the stiff light blue Nylex brand
water hose from hardware
shop.
BTW, theres another brand of smooth, flexible blue hose (Pope I think) that was called
drinking water hose, but I found it too was full of plastic taste.
167738
Follow Up By: snailbait (Blue mntns) - Wednesday, Apr 19, 2006 at 17:30
HI PHIL G
I tried everything to remove the plastic taste and i now use the blue nylex
drinking water hose the reson the food grade plastic hose taste is that the clorine in the
water from the town supply eats the hose where the blue nylex
drinking water hose is not efected by the clorine the words (
Drinking Water Hose) are branded on the out side of the hose
snailbait
423071
Reply By: Member - Phil G (SA) - Wednesday, Apr 19, 2006 at 08:50
Also, if you want to run your
water thru a charcoal filter, buy a white canister (like the under-sink units use) - the whole thing only cost $50 and the charcoal replacement filters are just over $20.
167739
Reply By: Glenn (VIC) - Wednesday, Apr 19, 2006 at 13:59
Hi Eza,
I have just bought a replaceable charcoal filter from Site Link and used it for the first time over
Easter. I found it to be great. It was the first time that the
water could be used for drinking.
Glenn
167793
Reply By: Graeme H - Wednesday, Apr 19, 2006 at 14:23
Try a product called EZ.RV it's a
drinking water freshner. Just add it to your
tank water. No flushing required. I bought
mine from a caravan acc
shop. Works a treat.
167799
Reply By: Member - Doug T (QLD) - Wednesday, Apr 19, 2006 at 18:11
When you want to buy stuff that is not directly 4x4 gear like
water tanks one should always check out the Truck Accessories shops as I did when i wanted a
water tank, No taste, right height and dimentions, right capacity 80ltr. and it fits in under the bed in my troopie, If it's no good Truckies won't use it,
www.bmackay.com.au/dp/
tank.html
Doug
167862
Reply By: Member - Melissa - Thursday, Apr 20, 2006 at 16:05
STRONG solution of Bi-carb, leave it in the
tank at least overnight, flush, bi-carb again, then flush and you should be right assuming as others have suggested that all hoses and
tank are food grade. If not food grade, replace them or you will never get rid of the tainted
water taste.
:o) Melissa
168094
