UHF Arial in roof lining Hilux TD 2005
Submitted: Friday, Apr 21, 2006 at 12:29
ThreadID: 33123 Views:2535 Replies:3 FollowUps:2
Has anyone run an arial inside the roof lining on a Hilux TD 2005? I have a inside roof console for my CB and need to get the arial up there. Any suggestions or experience with this?
Reply By: cabbageoz - Friday, Apr 21, 2006 at 14:44
And how do you think it might work up there?????????
AnswerID: 168317
Follow Up By: qldbushpig - Friday, Apr 21, 2006 at 14:50
Arial on bull bar...cable through to roof console.....OK????
FollowupID: 423610
Reply By: Alan H (Narangba QLD) - Friday, Apr 21, 2006 at 16:58
I have never done it - but I would approach it this way.
Pull lining off at a windscreen pillar at the door opening
Push solid wire (coat hanger) through to the console and attach cable to end of wire and then pullit through.
Same procedure up or down the pillar.
Just a suggestion!!!!!!!!!
AnswerID: 168341
Reply By: Member - Oldplodder (QLD) - Friday, Apr 21, 2006 at 17:12
In the old pajero with a roof console, I ran a piece of block PVC tube about 6mm dia running up the side of the windscreen tucked in tight to the window rubber.
Can hide it with some tape if you want.
Useful for the aerial, power cables and instrument cables, reading light cables too.
In the end I ran one large power cable and had a small fuse/distribution box in one corner.
AnswerID: 168346
Follow Up By: qldbushpig - Saturday, Apr 22, 2006 at 10:21
Many thanks for the suggestions. Much appreciated. Give me something to work on over the weekend.
FollowupID: 423768
