Error when posting ?
Submitted: Wednesday, Apr 26, 2006 at 10:04
ThreadID: 33253 Views:1859 Replies:6 FollowUps:7
Does anyone else get this message in red when they post something ? "There was a critical error executing your query The Error: Incorrect syntax near the keyword 'OR'." I get it every time but the post always seem to work OK.
Reply By: The Explorer - Wednesday, Apr 26, 2006 at 10:36
Hang on....
AnswerID: 169045
Follow Up By: The Explorer - Wednesday, Apr 26, 2006 at 10:37
No - works fine
FollowupID: 424392
Reply By: Michael B - Wednesday, Apr 26, 2006 at 13:14
Same with me Longreach,
Checked that the post had appeared, figured 'twas a puter glitch and did not bother about it. Maybe something for the 'guru'....
Michael B (SA)
AnswerID: 169069
Follow Up By: Michael B - Wednesday, Apr 26, 2006 at 13:16
This time was good......dunno
Michael
FollowupID: 424404
Reply By: ExplorOz Team - David - Wednesday, Apr 26, 2006 at 14:11
Guys,
I suspect the issue (looking at my logs) may be related to having a search running and updating a post. See if this gives us more clues - if we can re-produce it then I will be able to fix it. I have been seeing a log of search failures (which will give the error you reported) however I cannot work out how it happens as my testing alwasy seems to work. Let me know if you can find more info.
AnswerID: 169085
Follow Up By: Longreach - Wednesday, Apr 26, 2006 at 15:30
Hi David,
As I mentioned, no real issue but I was a bit curious as to why it pops up. Don't know if this will help but it just happened again and I wasn't doing a search (haven't done one today) but, not sure if this makes a difference, but I did try to reply to a post without first logging on and it told me I needed to log on which I then did and then posted the message (and then got the error). I am now logged on so we'll see what happens this time.
Cheers.
FollowupID: 424430
Follow Up By: Longreach - Wednesday, Apr 26, 2006 at 15:32
That worked without an error message. However, that was a follow-up and the previous post which generated the error was a reply. Not sure if that means anything though.
FollowupID: 424431
Follow Up By: Truckster (Vic) - Friday, Apr 28, 2006 at 13:24
Im getting this now
FollowupID: 424797
Follow Up By: ExplorOz Team - David - Friday, Apr 28, 2006 at 14:01
Where you running a query with GPS or Magellan and and EndDate?
There was a code problem with the EndDate field - I have fixed this one will see what happens to the logs now.
FollowupID: 424810
Reply By: Jo and Mark - Wednesday, Apr 26, 2006 at 15:54
I have often got the error message, but it hasn't made any difference to my replies, they still go up straight away.. I just figured it was maybe a normal website generated thing.
Jo
AnswerID: 169107
Follow Up By: Jo and Mark - Wednesday, Apr 26, 2006 at 15:55
Got an error message even with posting the above.. also thought maybe it was just something to do with being a visitor and not a member yet.
FollowupID: 424433
Reply By: David from David and Justine Olsen's 4WD Tag-Along - Wednesday, Apr 26, 2006 at 19:00
I get it everytime I post except when I post a follow up
AnswerID: 169148
Reply By: Muddies Doe(Trippn) - Wednesday, Apr 26, 2006 at 19:23
Hi Longreach
Yeap, only the once though with me.
It happened the other day when I was telling Roachie to have a great trip.
I have 3 posts almost the same.
The last one I gave up and refeshed it only to find that the 2 previous attemps had actually gone through but originally had said it didn't.
Cya
AnswerID: 169156
