AnswerID: 816 Submitted: Wednesday, Aug 01, 2001 at 00:00
Dion
replied:
Grant, I concur with the comments from Tony, my Rodeo Turbo is very quiet, but on Dads Hilux, it does whistle between 1000 and 2000 RPM before going quiet. The Rodeo's having direct injection do not need a long pre heat on the glow plugs, when switching on, if you blink, you will miss them. As far as being not satisfied with the 'punch' from your Turbo, how many k's has yours got on it? The turbo will be working, but if the clearences have diminished, the turbo will not be able to provide the required boost, this usually occurs if the turbo has had any sort of a bearing failure, or a bearing that has slightly worn.
Dion.
Reply 2 of 2
