plastic taste
Submitted: Thursday, Apr 27, 2006 at 22:20
Mr F
Does anyone know how to get rid of the plastic taste from a new
water tank
Reply By: Member - Paul P (Bris) - Thursday, Apr 27, 2006 at 22:22
G'day
Using the
forum search feature search using keywords - plastic taste - and the answers shall be delivered.
Paul
169396
Reply By: geoffd51 - Thursday, Apr 27, 2006 at 22:45
Hi Paul if you wash your
tank out with a solution of bi-carb of soda this should fix the problem. You might have to do it a few times.
169401
Reply By: Rod - Thursday, Apr 27, 2006 at 22:53
vanilla essence works with
water
169404
Follow Up By: macca172 - Friday, Apr 28, 2006 at 06:43
Rod,
Im with you mate, vanilla essence is the way to go! My late mum used to wash the refridgerator out with a mixture of vanilla essence and
water as
Macca
424738
Follow Up By: agsmky - Friday, Apr 28, 2006 at 06:58
I'm not following.....what's the go with vanilla essence that could possibly remove a plastic taste? I thought VE was used in frigs to mask smells and the true VE with its alcohol, may kill some bacteria etc in a concentrated form.
424740
Follow Up By: Rod - Sunday, Apr 30, 2006 at 16:30
dunno, but it works. tried and true
425188
Reply By: Redback - Friday, Apr 28, 2006 at 08:31
I did this in my campertrailer put in a home
water filter, the
water now taste bloody brilliant and also i can fill the
tank from anywhere now and the filter cleans the
water.
Baz.
169425
Reply By: Sand Man (SA) - Friday, Apr 28, 2006 at 08:51
Bi-Carbonate of Soda is cheap, readily available from any
Supermarket and will not leave a taste of it's own.
169429
Reply By: Member - Phil G (SA) - Friday, Apr 28, 2006 at 09:28
A lot of the time, the tatse is in the plastic tubing, and not the
tank. I eliminated
mine simply by replacing everything - including fillers and breathers with Nylex blue
drinking water hose.
169439
Reply By: Member - uncle - Friday, Apr 28, 2006 at 11:20
I just learned a valuable lesson on the last trip away,run the hose
water for a minute to get all the stale
water out before filling!! Our hose is 60ft long and the taste left in the
tank was yuk....!!cya
169454
Follow Up By: Jimbo - Sunday, Apr 30, 2006 at 17:42
Give Uncle the Cupie Doll.
I've had
water sit in two new
water tanks and 4 plastic jerries for months and it doen't taint. I run
water through the hose for at least a minute before putting it anywhere the
tank or jerry I am planning to fill.
This is the secret, put fresh
water into your
tank.
425205
