FollowupID: 425509 Submitted:
Monday, May 01, 2006 at 23:47
V8 Troopie posted:
They don't have to be heavy nor hard to pack to work, its just a matter of a little lateral thinking.
My fist trip into the desert many years ago was with an unsuitable 4WD (insufficient ground clearance). So, lowering the tyre pressure made little difference in crossing dunes as the car bottomed out in the wheel ruts.
What got us through were 6 lengths of 25mm x50mm section mesh, about the length of the bull bar and about twice as wide than the wheels. They could be hooked together to make a long track. It was a simple home made solution that did the trick.
Yes, they got a bit bent after the car passed over it but they were easily straightened by jumping on them. They were carried tied to the bull bar when not in use, easily got at and they packed away just as easily, fairly light too as the wire was only 3mm thick. The hardest part was finding them again after passing over as they just disappeared in the loose sand, ended up tying colored ribbons to each to spot them easier.
A few years later I did the same trip in a more suitable car (my troopie) and had no problems with the dunes until I decided it would be a nice place to take a picture and stopped on top of one. Troopie bogged, had no LSD nor any diff lockers back then. The grids saved a lot of digging and got us rolling in no time. Even the weight of the troopy did not bend them beyond usability, I still have the grids in the shed ready for a future trip.
I would imagine they work well in mud too, did not have to try that one yet ;-)
Klaus
