AnswerID: 170102 Submitted: Monday, May 01, 2006 at 20:11
Member - Paul P (Bris)
replied:
G'day
I would suggest that you use
Alice Springs as a start and return point for the Ularu,
Kings Canyon Mereenie Loop etc sections. Alice is a major centre and allows good shopping and vehicle repair facilities.
Mereenie Loop - it was very wet (and muddy) when I travelled it last year. The locals reconded it would be all sealed in 12 months. There was a lot of raod works on it.
Tanami - a little over 1,000k from
Alice Springs to
Halls Creek. Only about 200k is sealed. As stated Tilmouth is the end of the seal.
Suggest - Depart
Alice Springs with full tanks - Top up at Tilmouth and experience a "Burger with the Lot" as well. Being an overseas visitor Rabbit Flat should not be missed (be aware of his opening times). Get fuel there as well and also camp the night in his camp area.
The depart to Wolf Creek and camp the night at the National Park camp area. Have a look around in the morning and then to
Halls Creek. From
Halls Creek choose your route.
The Tanami is a comfortable 80kph road (usually). A little rain will cause it to be closed. Fueling at the above suggested
places will still mean you will need a comfortable 600k fuel range. It can be badly corrugated, particualrly around the mines ( Rabbit Flat area) due to high speed mine traffic.
Whilst you may be tempted to travel the Tanami in one day I would suggest not. A one day crossing is for the experienced with suitable vehicle and at least a 1000k fuel range after topping up at Tilmouth Well. Two nights is comfortable and allows for a look around.
My thoughts
Paul
 | Anything is possible. |
Reply 3 of 6
FollowupID: 425468 Submitted:
Monday, May 01, 2006 at 20:24
Member - Paul P (Bris) posted:
As Eric M said. The Tanami is remote so carry sufficient food, water and fuel. Whilst you see and pass other motorists if you break down assistance may be many hours arriving (even a couple of days).
Walking out of trouble is NOT an option in this area.
Be a qualified First Aider and carry a suitable
first aid kit. Mobile phones do not work in this area ( and also a lot/most of the Kimberleys).
Understand the use of 4wd high range on dirt roads and use high 4wd when appropriate. I spent a great deal of last years journey in high 4wd whilst traveling the Tanami. Makes for much better vehilce control and stability.
Lower tyre pressures may be appropriate but watch tyre heat build up.
Make sure your rental company
permits its vehicle to travel the roads you plan to use.
Paul
