Site Search
Section Image
Prado 120 owners - replacing wheel bearings in the field
Submitted: Tuesday, May 02, 2006 at 12:13
Member - Drew T (VIC)
I'm stocking up on my spare parts for a forthcoming trip up the Canning. I am consistently told that the Prado 120 wheel bearings are a fully sealed unit & replacing them in the field is not viable for a non-mechanic like me. They are bloody expensive too!
Has anyone actually had any experience changing them & have a different view?
Click Image to Enlarge
Prado120 GXL V6 Auto
Wonangatta Valley
Advertisement
ThreadID: 33450 Replies: 3
Views: 997 FollowUps: 9
AnswerID: 170216   Submitted: Tuesday, May 02, 2006 at 13:27
Member - Stan (VIC) replied:
I am doing Madigan Line/Hay River Later this year and this is
so far a list of spares to take with me. This is a list as advised by
the guy who knows Prados/Suspension stuff very well:
Gloves, 2 straps, jack, jacking plate, rated hooks,2 x bow shackles.
Tyre gauge, Air Compressor, Sand Flag
Radiator hoses - top and bottom, heater hose - 1.5m (16mm diameter)
serpantine belt, fuel filter, air filter,
wheel nuts and studs,
1lt engine,gearbox/diff/trans oil
Spare shocker washers, rubbers, locators, and mounting bolts including spare front and rear shock (You'll need a spring tensioner to change the front shock)
2 spare tyres, tyre repair equipment
Rated recovery points front and rear
Hope this helps,
Stan
Madigan Line Jump
120 GXL V6 Auto
www.lcool.org - Landcruisers Owners On Line
120scool - http://autos.groups.yahoo.com/group/120scool/
Reply 1 of 3
FollowupID: 425576   Submitted: Tuesday, May 02, 2006 at 14:03
Member - Drew T (VIC) posted:
thanks Stan. almost exactly the same as my current list except i will now add spare wheel nuts/studs. I'm just taking the old (Toyota) front & rear shockies as spares so didn't think I'd need separate washers/rubbers/locators/mounting bolts in addition to those?
Note that I also have on my list a qty of type A fuses (mini spade), a 50A type B, & a 120A type C fuse.
Wonangatta Valley
FollowUp 1 of 7
FollowupID: 425601   Submitted: Tuesday, May 02, 2006 at 16:26
Member - Phil G (SA) posted:
Stan,
If the 120 is like the 90series, the front and rear wheel studs are slightly different. If I were you I'd buy 3 of each. They did look to be interchangable - main difference was the length of the spline - and they were the same as the ones on an 80series.
Also, in addition to Drew's fuses, a bit of fusible link wire is a pretty useful spare out in the desert.
Mt Finke
LandCruiser HDJ79
FollowUp 2 of 7
FollowupID: 425611   Submitted: Tuesday, May 02, 2006 at 17:30
Stan, was also told by a 4WD mechanic today that changing the front shockies on a Prado120 in the field is a big difficult job .. he reckons still carry the spare shockies, but i'm probably better off driving on the failed shockies to a workshop that has the proper facilities. Well i'll still carry the spare shockies & spring compressors but will think carefully about whether i'll replace them myself beside the track!!
Wonangatta Valley
FollowUp 3 of 7
FollowupID: 425669   Submitted: Tuesday, May 02, 2006 at 19:43
Member - Stan (VIC) posted:
Drew, if you got washers/rubbers/locators/mounting bolts on the old Toyota shockers, then you will not need another spare lot. Yes, agree on changing failed shocks in a workshop, the spring compressors is for the worst case scenario if the shock's eye brakes off and you can't weld it on the car...
I have added a fuses and fusible wire to my list.
Madigan Line Jump
120 GXL V6 Auto
FollowUp 4 of 7
FollowupID: 425671   Submitted: Tuesday, May 02, 2006 at 19:46
Phil,
Yep, got 6 wheel studs and nuts supplied by Darren for last year Simpson Trip,
so I assume they are correct ones :)
Madigan Line Jump
120 GXL V6 Auto
FollowUp 5 of 7
FollowupID: 425858   Submitted: Wednesday, May 03, 2006 at 15:01
Stan. just fyi ... picked up some studs/nuts from toyota & the guy confirmed for me that the front & rear studs are different. i just measured them - the fronts are about 45mm long & the rear ones about 50mm (total length)
Wonangatta Valley
FollowUp 6 of 7
FollowupID: 425939   Submitted: Wednesday, May 03, 2006 at 20:25
Drew, I reckon the splines are the same diameter, so if you had to interchange them, then that would be possible.
Mt Finke
LandCruiser HDJ79
FollowUp 7 of 7
AnswerID: 170218   Submitted: Tuesday, May 02, 2006 at 13:37
Member - Tony G (ACT) replied:
If it concerns you change the wheel bearings before you go. The list that Stan is carrying sounds great for that type of trip.
Tony
Reply 2 of 3
AnswerID: 170245   Submitted: Tuesday, May 02, 2006 at 16:20
Member - Phil G (SA) replied:
Don't worry about the wheel bearings. They are sealed and won't give you a problem on such a young vehicle. I've only heard of one other person needing to replace them on a 90series, and that was after 150,000+km. Rear wheel bearings are semi-floating.
Dinosaur vehicles like mine need to carry them :-((
Mt Finke
LandCruiser HDJ79
Reply 3 of 3
FollowupID: 425915   Submitted: Wednesday, May 03, 2006 at 18:40
Gu_Patrol posted:
A friend of mine had stuffed front wheel bearing after 25,000 kms on his 120 prado, the ARB guys in Regency park noticed them. It pays to get a good look over before you go.
FollowUp 1 of 2
FollowupID: 425940   Submitted: Wednesday, May 03, 2006 at 20:26
Must have been like that from the factory. Agreed, need to be checked.
Mt Finke
LandCruiser HDJ79
FollowUp 2 of 2
 Page Sponsors
Phone: 1800 21 21 21
ExplorOz ExplorOz
Phone: (08) 9403 3737
More info | Website
