ARB Rack modification to suit Rooftop Tent
Submitted: Tuesday, May 09, 2006 at 07:11
dan@dbw
Gathered masses,
Has anybody modified an ARB rack to suit a roof top tent? I know you can buy the rack to suit the roof tents but seeing I have this one... Which I just picked up very cheap.
I'm just thinking of trimming the top bars off where the tent would sit to allow it to sit down in the rack.
Will I have to strengthen the rack or will it be sufice?
I'm currently running the tent on 3 bars but I need to carry an extra spare up there etc and the 3 bars have made an impression on the tent (needs better support).
Thanks in advance.
Reply By: Member - Tony G (ACT) - Tuesday, May 09, 2006 at 08:47
You have got the best rack for the job, just get it modified to suit the tent and spare.
171657
Reply By: Grumpy in WA - Tuesday, May 09, 2006 at 10:31
Hi Dan,
I have a rack for a roof tent, it a base that sits on to 3 cross bars and its attached with u bolts. I don't have a roof tent any more so if you are interested in this one then let me know. I don't know where you are, we are in
Perth now.
It won't cost you a fortune and It'll save you wrecking your ARB rack.
171681
Follow Up By: dan@dbw - Tuesday, May 09, 2006 at 11:05
Hi Grumpy,
Thanks for your reply, I'm in
Sydney so I'd say postage will be the killer!
Thanks anyways.
427143
Reply By: Middle Jeff - Tuesday, May 09, 2006 at 21:59
Hi Mate
I did the same thing as you are about to do and it works great, out with the grinder and cut off anything you don't need. I left the rails around the front to strap my cargo bag onto.
Have fun
171824
Reply By: Flux - Wednesday, May 10, 2006 at 17:55
Hi Dan, Yes I've modified an ARB rack.
I picked up a cheap 2nd hand ARB full length rack - (steel boxy style)
I then chopped the upper rail (and verticals) off on the rear section so there was enough room for the tent. Next I welded the rear section I had cut off back onto the back of front half- which made a smaller basket at the front, and left the rear open for the tent.
This has worked perfectly for my application, cost was minimal and only took about 2 hours including repainting.
Flux.
171969
Reply By: dan@dbw - Thursday, May 11, 2006 at 06:36
Cool, thanks guys. I will no doubt look into it more on Sunday when I have some time off!
One more question, Do you know what colour that ARB
grey is? Also where to get it? Just in spray can will do, that way I can touch up and won't be so stressed about items rubbing the pain off.
172072
