hundred series engine question
Submitted: Tuesday, May 09, 2006 at 08:48
ThreadID: 33705 Views:1979 Replies:2 FollowUps:3
G'day,
just wondering if anyone can tell me what the two steel pipes that attach via a single bracket to the front of the cross member of the chassis rail below the radiator on a 100 series are for? If that made any sense... And, does anyone know of a mob that makes a bash plate that can be attached to protect these pipes from stone and rodent damage?
Chris
Reply By: crewser - Tuesday, May 09, 2006 at 09:01
power steering pipes from p/s pump to p/s box. don`t know if anyone makes a bash plate, would be pretty easy to make one your self but would need holes/slots in it to let air through to radiator.
AnswerID: 171661
Reply By: traveller2 - Tuesday, May 09, 2006 at 11:16
They stick them out there so the airflow can cool the power steering fluid.
The hotter the fluid is the greater the wear on components and in an extreme loss of steering assist.
AnswerID: 171686
Follow Up By: Ando79 - Tuesday, May 09, 2006 at 11:44
It's a pitty they dont supply a perforated bash plate because the ones on my truck are so badly damaged that one more roo I'd say would see them finished off. I am having a fight with the dealer I bought it off to get them replaced under warranty. The bracket that holds them on is also missing. Danged ex-government vehicles...
FollowupID: 427151
Follow Up By: traveller2 - Tuesday, May 09, 2006 at 15:13
You could always replace them with a small auto trans cooler mounted up higher out of the way. Bigger surface area and extra fluid in the system (bigger capacity) will negate poorer airflow probably.
FollowupID: 427201
Follow Up By: Ando79 - Tuesday, May 09, 2006 at 15:15
Nice. Thanks for that.
FollowupID: 427203
