Dual Batteries for 100 series Landcruiser
Submitted: Tuesday, May 09, 2006 at 10:02
ThreadID: 33709 Views:17091 Replies:5 FollowUps:4
I would like to know the best way to do a dual battery system for a 100 series Landcruiser?Do I put a third battery in or just split the front two batteries and replace with larger batteries????Will the car start under very cold conditions eg.snow??????
Reply By: Member No 1- Tuesday, May 09, 2006 at 10:37
yeah whats the go...i get mine in a weeks time, so i too need the answer
AnswerID: 171682
Reply By: Member - Andrew W (SA) - Tuesday, May 09, 2006 at 10:46
Depends on your planned usage.
Even with a fridge/freezer, my big deep cycle second battery rarely hits rock bottom (although I usually don't stay in one place for more than one day).
I do have permanent jumper leads between the main calcium/calcium starter battery and the second deep cycle - large diameter cables with 175A Anderson plugs that I can just connect/disconnect with a minimum of fuss and no risk.
Ciao for now
Andrew who would have trouble finding space for a third under the bonnet.
AnswerID: 171683
Follow Up By: Derek from Affordable Batteries & Radiators - Tuesday, May 09, 2006 at 16:43
Hi Andrew,
Stickers and product catalogues are ready. I will send you some.
Regards Derek.
FollowupID: 427211
Reply By: Derek from Affordable Batteries & Radiators - Tuesday, May 09, 2006 at 16:41
Hi Barely
I think you are talking about the diesel in which case you have 2 options.
1) Move the fuel filter and fit a 3rd battery over the L.h. Wheel arch.
or
2) Fit a controller between the 2 main batteries and fit 1 High cranking battery and 1 100 a/h aux.
Regards Derek.
AnswerID: 171742
Reply By: Richard W (NSW) - Tuesday, May 09, 2006 at 17:34
I run a 55A/H Optima Yellow Top in the rear of the vehicle through a Pirahna isolator mounted under the passenger seat. Has done the job for a number of years running an Engel 40L fridge and sundry 12V appliances including a 300W inverter. Really needs to be charged up each day. I have had it tested and it is OK.
Just purchased a Twozone so I'm looking to upgrade the battery to an AGM of much higher A/H.
AnswerID: 171764
Reply By: ACDC - Tuesday, May 09, 2006 at 21:04
Well fella's
If it was my vehicle i would fit the third battery and make this the starter battery,then use the other two as the aux batteries this would run a decent fridge for up to 4-6 days instead of flogging the guts out of one battery.
AnswerID: 171808
Follow Up By: ACDC - Tuesday, May 09, 2006 at 21:10
Also i 've tried different brand trays in the 100 series diesel and found the TJM tray the best.
FollowupID: 427288
Follow Up By: Derek from Affordable Batteries & Radiators - Tuesday, May 09, 2006 at 21:10
Hey ACDC,
Nice idea, I will check the main leads on the next one that comes in and see if they will reach the 3rd battery.
You can even use the 2 standard batteries as auxillary until they die and then replace them with AGM's.
Regards Derek.
FollowupID: 427289
Follow Up By: ACDC - Tuesday, May 09, 2006 at 21:21
Derek,
I agree the 2 std batteries would last for years!
FollowupID: 427298
