Navara STX height problem
Submitted: Thursday, May 11, 2006 at 14:55
itsdave
I have ordered and am waiting for a D 40 but in the meantime am wanting to order a canopy. My problem is only having 2.03 metres clearance into the garage.
Seems the only ones suitable are the standard height ones i.e flush with the cab and the only ones I can find are ARB and Flexiglass, TJM to date do'nt make a low one and Carryboy want $3400 for one
I prefer the ARB but unfortunatly it rises up towards the rear making it higher than the cab. From what I can estimate, tray plus canopy plus roof racks, gives an overall height of exactly 2 metres, not a lot of clearance.
I would like to know if anyone else has a similar setup and if they can confirm these measurments or any alternatives.
Cheers Dave
Reply By: Rosco - Qld - Thursday, May 11, 2006 at 17:08
I'm not familiar with your proposed vehicle, but I had a similar problem with
mine and the garage. Initially it was as tight as a new bride .. ;-)
But after a relatively short period of time the
suspension settled in and overall height probably dropped about 10+ mm.
You would most likely experience something similar.
172157
Follow Up By: itsdave - Thursday, May 11, 2006 at 17:20
It's the new 2.5 ltr turbo diesel navara duel cab
427749
Reply By: big fella - Thursday, May 11, 2006 at 20:20
Hi Dave not so shore but i am pretty sure arb make a canopy that is one continual height and one that rises up at the back like you are saying
Regards BigFella
172180
Reply By: Member - Blue (VIC) - Thursday, May 11, 2006 at 20:25
My ARB canopy on the Triton is pretty dead level... Design may hace changed since '03 though... After about 10,000km, my rear
suspension settled almost exactly 10mm, as mentioned previously. I guess the other problem will be if you decide you need more clearance and eant bigger rubber or a lift. Can the garage be easily modified to suit...?
172181
