second-hand 3.0 GU
Submitted: Saturday, Feb 15, 2003 at 14:19
ThreadID: 3381 Views:2511 Replies:7 FollowUps:10
G'day, I am looking at buying a second hand 3.0l Patrol. I have heard a lot about the oil presure problems etc and I am interested to know if this is resolved? Phil
Reply By: brian - Saturday, Feb 15, 2003 at 16:15
Hello Phil,what problems are you referring to,havent had any problems with either a 2000 model or my current model,please let us know.happy travelling.
AnswerID: 13199
Reply By: PeteG - Saturday, Feb 15, 2003 at 17:47
Phil,
The GU II 3.0l was released in May 2000. In Dec 2000 there was a recall to fit a new dipstick and oil pickup. This increased oil cap from 8.0l to 10l. Not sure of the reasons behind this although did hear a rumour about failure to keep lube pressure on steep slopes (ie was sucking air).
Another problem has been the 5th gear stripping at the mainshaft spline. Most vehicles would have had this happen in the first 75000K's Nissan have released a revised shaft & cog with an increased boss length.
Personally I would regard a turbo timer as mandatory. I believe the NSW Police force has experienced some issues with turbo bearings through quick shutdowns.
Some vehicles have had issues with computer chips - there has been an upgrade chip issued to those who complain. The air control valve has been a bit of an issue on a few vehicles.
I have also been told to watch the fitment of CAV type filtration as they are getting a few failures due to starvation caused by the finer filtration (and aparrently CAV are putting a note in the box advising not to fit to electronic diesels)
I have a 3.0l with 120ks. Have heard of one with 185k's and one 12mths ago with 155k's then.
Mine has had the sump, 5th gear and new chip under warranty. Have also had turbo replaced due to the cone actuator failing (probably a $50 part) but not serviceable and hence $6k for a new assy - fortunately under warranty. The first 75k's the vehicle went well, (5th gear done at 72k's) and since then have had issues with intermittent power loss (now fixed) but is still a little off song now. Still pursuing these issues under warranty and it has taken 45k's to get as far as I have.
All up they go well on the highway and despite the knockers the motor does lug reasonably well. Believe the motor originated from a european truck so has been around a little bit. The same motor is now used in the Navara without the Intercooler.
If doing a lot of heavy towing I would look at the 4.2l as the 3.0l requires a bit more work on the stirrer to keep revs above 2000rpm in order maintain reasonable progress.
I will be replacing mine in 4mths and will get a Nissan again but giving some thought to the 4.2l.
In all honesty I think the underlying motor is sound, however, as with all things new I thihk there have been a few teething problems.
Certainly do all the usual pre-purchase checks and check the driveability of the vehicle out in a variety of situations.
The Nissan Patrol Group at Yahoo is worth a look at for more info.
Pete G
AnswerID: 13203
Follow Up By: Shep - Saturday, Feb 15, 2003 at 22:19
Pete , I`m also looking at buying one of these units ,does Nissan list these warranty mods in the service manual/log book ?
Shep
FollowupID: 7738
Follow Up By: Derek - Saturday, Feb 15, 2003 at 23:18
Pete G. I believe the 3.0 engine is an Isuzu one and I think I read on this forum, a posting by Truckster saying that Nissan are releasing a new 6 cyl diesel with electronic ignition and OHC in the near future.
FollowupID: 7748
Follow Up By: Peteg - Sunday, Feb 16, 2003 at 10:32
Shep,
No they don't specifically note it in the book, so case of buyer beware.
That said though Nissan do keep a computer service history of the vehicle (if that gets filled out properly) where servicing is done by a dealer.
FollowupID: 7765
Reply By: Phil - Saturday, Feb 15, 2003 at 18:04
Thanks Pete, you have answered all of my concerns and Brians question as well. I'm buggered if I know what to do at this stage, so that means I will do nothing at the moment. Ill take my time and really look around. Again thanks for taking the time to so comprehensively answer my Q. Cheers, Phil
AnswerID: 13205
Reply By: colin - Saturday, Feb 15, 2003 at 18:47
Any 4x4 vehicle over 2 tonne with a small 6 or a 4 cylinder diesal is worth nothing under our conditions, toyota has got it right raw horse power. I drive a 92 4.2 super charged patrol which have proven to be a bullet prove donk, i tow a camper trailer and do a lot of black top driving but a lot more off road trips. Off road i keep the revs between 900 to 2000 revs which gives me heaps in reserve for the play times, have done over 250,000ks and havent touched motor or any of the driveline. I think people expect to much from the small fragile eguipment nissan is putting on the market to sell vehicles. Heavy vehicles need big donks for longtivity. The only vehicles i have trouble keeping up with are the 80 and 100 series toyota, but thats modern tecnology. Col
AnswerID: 13207
Follow Up By: Craig - Saturday, Feb 15, 2003 at 22:30
Colin , I don`t quite argree with the small 4cyl & 2 tonne 4x4 don`t mix.
take for example a 8cyl truck that weighs 8 -10 -12 tonne or more if carring a load . Match the cylinders per tonne? It`s all in the running gear.
I suppose we`ll have to wait till the 3.0lt age b4 all the speculation of how good they are or how long they last will disappear.
Craig.
FollowupID: 7739
Follow Up By: Derek - Saturday, Feb 15, 2003 at 23:14
Colin. You're last comment surprises me. In my club we have 2 members(amongst others) who drive GQ patrols. One has a petrol and the other a diesel with a commodore super charger. The diesel can keep up with the petrol on the flat AND the hills and can easily hold its own against a turbo GXL (probably not the latest 4.2 though). As for my 1HZ and the other n/a 4.2 GQ's, we're not even in the race. Is your engine performing at its best?
FollowupID: 7744
Follow Up By: Colin - Sunday, Feb 16, 2003 at 13:33
Derek, i was talking about the latest toyota donks with ohc multi valve and electronic pumps and a turbo. My patrol is running at peak performance, and am very happy with the performance but a pushrod motor against modern technology i think that speaks for itself.Col
FollowupID: 7771
Follow Up By: Colin - Sunday, Feb 16, 2003 at 15:08
Craig, you only have to look at this forum to see how many people are trying to get more power out of their 2.8 patrols as they have nothing down low in the rev range. As for the 3ltr they have already proven they are a piece of crap for the aussy conditions. Col
FollowupID: 7773
Follow Up By: Suzuki Viagra - Monday, Feb 17, 2003 at 17:15
2.8 Patrol petro engine was first desingned as a 2 litre inline 6 for sports cars in the 60's. Moast notable used in the 2.4 litre L24 (240 Z and the L16 Datsun 1600 - L24 with 4 cylinders instead of 6).
Not a good motor for 4wd purposes or a modern motor when used in the Patrol - although Datto 1600 entusiasts and the Datto 1600 dirt rally history might suggest otherwise.
Good news is datto 1600's could go out to 2150 - a 120 thou overbore. The factory overbored it to get 2.8 but 3.1 is easy and 3.9 Litres is possible with the right Nissan diesel crank and overbore pistons, wiht facoty turbocharged manifolds on top of that.
Most people just fit a 308 V8 or 350 Chev in em now.....
The Commodore 3.8 V6 is becoming a very good option now due to price of seconhand motors....
FollowupID: 7820
Follow Up By: Colin - Monday, Feb 17, 2003 at 18:42
Hi viagra, sorry but i am a diesal man and was talking about the 2.8 turbo diesal. I disagree about the donk you where talking about i had a mq with the 2.8 petrol and found it to be a good reliable donk which loves to rev right out. That vehicle took us all around auss, including the cape and the gibb river. You awnsered another site and my mistake i said the patrol was over 4 tonne pushed the wrong button should be 2 tonne, but i still stand by a small donk in a heavy vehicle is not worth bleep te. So viagra have you ever owned a large 4x4. Col
FollowupID: 7823
Reply By: Suzuki Viagra - Monday, Feb 17, 2003 at 15:59
As Colin has pointed out some people have had issues with the non-turbo 3 litre and Nissan has now "improved" on it - time will tell whether or ot this addresses all the issues...
For "traditional" dieselists out there - come in number 23 your time is up. World emissions standards mean that diesels have to adapt to new technology as much as any other type of car - no more cam operated mechanical fuel pumps as per 60's petrol engines. Nissan met the required standards with the old 3 liter and didn't have to make too many changes to the old one to get to the new one and the new standards - it wasn't that far off the pace unlike what was suggested in this forum....
It would quite easily be possible to update the "old" 3 litre with the changed components - only consideration is how much do nissan want for the parts - probably big $$$$$$
Turbo diesel is the far better option. Actually in my view the 4.2 Petrol is the far better option, Electronic pumps, electronic ignition or direct injection are all just ways of "de-dieseling" the motor to make it more liveable. If you want that but still want diesel go the Pajero Di-D.
Howls of complaint can be adressed to: Suzuki Viagra
PS: Pushrod? OHC? MultiValve? - A pushrod engine is definately going to be OHC or there's no point in running the pushrods......... If you aint OHC you can't multivalve anyway - then it's called porting - and that still didn't prevent 300bhp per litre from sidevalve engines..... try a seven port per cylinder NSR-V 500
AnswerID: 13314
Follow Up By: Colin - Monday, Feb 17, 2003 at 18:53
Viagra , sorry but i dont understand how you have a ohc on a push rod donk as ohc are driven by a belt or chain taking away the need for push rods. Col
FollowupID: 7825
Reply By: jeremy - Monday, Feb 17, 2003 at 16:45
To all the knockers of 3lt Patrols...........
seems to me that you guys are the ones who can`t afford a new car just now and are putting down these excellent vehicles to make yourselves at ease.I lashed out for one of these Patrols because any one who has owned a Nissan of most descriptions will tell you that Nissan don`t build bleep ,,,,,either does Toyota for that matter but who can afford a 100series?,,,not me!
Yes its true they do lack a bit of low end torque and they`re probably not suited to long term heavy towing,,but bloody hell they are good value for money.Mine goes most places comfortably offroad and tows our camper trailer comfortably ,,passing many passenger cars that are towing up hills.I have owned a petrol 4wd and got sick of their piss poor fuel economy on high country jaunts and trips to the dunes of Robe,,yes i had to buy jerry cans ,,now they gather dust in the shed.Long live 3lt Patrols , i love `em
AnswerID: 13322
Reply By: Suzuki Viagra - Monday, Feb 17, 2003 at 17:25
Jeremy was happy with his - Nissan didn't chnage much - hence you should be happy.
Realise that every vehicle will have unhappy customers - either due the customer not doing the required research, the salesman doing a snow job, or the occasional faulty car.
best solution is try one and see if you like it with all our feedback in mind and of course, make sure you try the direct competitors.
Overall most people (but not Hardcore crusher addicts) think the early GQ in both petrol and diesel forms was miles in front of the cruiser. Obviously Toyota did what it could to resolve this and the tables are currently reversed - all new Patrol should finally be out this year or 2004 with an option of 5.4 32 Valve V8 petrol.
I think the current Patrol is still ahead of the Cruiser - but that is my opinion and I havem' had the pleasure of testing all models over all terrains - even 4WD of the year didn't do that as the Nissan was not eligable - it was a January Model.....
AnswerID: 13325
