surface rust
Submitted: Sunday, May 14, 2006 at 00:00
ThreadID: 33873 Views:4245 Replies:5 FollowUps:0
i know this post has probably been asked @#$ times before but the only thing i have found on the search function is regading rust on the roof or the electronic rust profing
any ways i just recently scored a gu patrol the brother in law, but it has spots of surface rust around parts of the chassies. in just wondering whats the best way to get rid of it or is there a product that will slow it down or get rid of it? any info would be great help
thank you
Reply By: The Rambler( W.A.) - Sunday, May 14, 2006 at 01:04
Fisholine--available at Bunnings.Leaves a smell that will dissapear in a few days.It is very good stuff.
AnswerID: 172591
Reply By: Member - Reiner G (QLD) 4124 - Sunday, May 14, 2006 at 07:49
Yes Fisholine works well. I still got my HJ47 81 mod and it has very little rust. I used to spray mine every year and do the same with my new one.
Reiner
AnswerID: 172593
Reply By: Mr Fawlty - Sunday, May 14, 2006 at 13:22
If you want to do a proper job buy yourself some "Deoxidine 624" from an Automotive paints supplier and apply as directed. Then if you can actually get near the rusted areas give it a spray or brush on some cold gal paint. If not then the fisholene would do the job for you. The Deoxidine will kill the rust and passivate the surface. I don't advise the use of the spray on bitumen type paints on older chassis that may have hidden rust as the rust will love the atmosphere under the bitumen and the situation will deteriorate.
Corrosion is a hobby horse of mine, had vast experience treating it in boilers where it does tend to be worrysome.
AnswerID: 172627
Reply By: F4Phantom - Sunday, May 14, 2006 at 13:50
Penetrol amuminium is excellent, I paint the stuff directly onto rust and it is supposed to last 15 - 20 years. If you get 5 to 10 thats fine. It seals the rust out and does not allow contact with air or water. I have yet to see rust get through that layer.
AnswerID: 172631
Reply By: Member - Oldplodder (QLD) - Monday, May 15, 2006 at 08:16
Agree with the one above.
Penetrol on the rust, and I use fish oil as a general deterrent.
Friend used to have a hose set up for his compressor with a 180 deg spray nozzle on the end. We used to drag it through all of the chassis members.
Then a good general spray around underneath.
Add a bit of diesel to make it go further and penetrate better.
PS - wives love the smell of fish oil and fish oil burning off a hot exhaust!
Really turns them on - to some one else.
AnswerID: 172713
