Re Blocks forTruckspring air bags
Submitted: Tuesday, May 16, 2006 at 20:17
Mark (Geelong)
I purchased Coilrite Air bags from trucksprings in US and as my Patrol has 50mm lift I needed the Blocks to go beneath the air Bags
I found they are available from TJM and purchased them today here in
Geelong at cost of $20 ea
I was going to make them up myself but as i found these it will save me the trouble
They also include a bolt and Nyloc nut to secure them to spring mount
Reply By: PK Eildon (VIC) - Tuesday, May 16, 2006 at 23:41
Got
mine today. Question you may be able to answer. The black top blocks, do they go flat side down or up. I assume flat down against the bag. Instructions do not specify.
173055
Follow Up By: Mark (Geelong) - Wednesday, May 17, 2006 at 16:39
I havent fitted
mine yet but took a look underneath the other day
As best as i can determine the blocks supplied go flat side down and the rebate should fit inside the coil support
I hope that is correct
Good luck
Let me kow how you get on as I wont be fitting
mine until a couple of weeks time
The Blocks for the base if you have a lift come supplied with bolts
428990
Reply By: mick - Wednesday, May 17, 2006 at 10:34
hi mark.im in the market for the coilrites ,do the people over ther know what a patrol is? also how much are they in aussy dollers regards mick
173108
Follow Up By: Mark (Geelong) - Wednesday, May 17, 2006 at 16:43
No I dont think they know what a patrol is
The part no for GU Patrol is 4129 and they cost $187 delivered to Australia in 6 days
Great service from the yanks
428991
Reply By: Member - Jeff M (WA) - Wednesday, May 17, 2006 at 19:53
Ummm, you don't need to fit spacers to air bags. Air bags work by squeasing through the sides of the coils and effectivly stiffening up
the springs, not by taking the weight of the vehicle instead of the spring. When I put my 2" lift in the back I enquired about the same and then was instructed not to. I didn't and they have been spot on for over a year like that, work just as they did without the lift. In fact the theory goes that they will probally last longer as they are not under as much stress at full articulation etc...
173195
