rims for jayco
Submitted: Monday, May 22, 2006 at 14:43
ThreadID: 34133 Views:4250 Replies:4 FollowUps:1
Hi All,
I recently posted a thread to try and get a pair of rims to fit an 02 Jayco Freedom caravan {14's} someone called Wizard said that a Ford rim would fit , anyone know what kind of Ford ? they are 5 stud,
thanks in advance,
Reply By: Wizard1 - Monday, May 22, 2006 at 14:50
Dave,
I purchased a second spare for my van and just grabbed a rim off a Falcon in the wreckers yard. I think it was an XD but that shouldn't matter as they are all same stud pattern.
Wizard
AnswerID: 173971
Follow Up By: Dave Thomson - Monday, May 22, 2006 at 15:09
Thanks Wizard , do you remeber what they cost ?
P.S. are you the guy thats got a Prado ?
Davy
FollowupID: 429940
Reply By: macca77 - Monday, May 22, 2006 at 15:22
I thought that they all were ht stud pattern. If so carac in melbourne will be able to supply you. If they are not ht and they are ford any tyre mob will have something for you regards macca
AnswerID: 173979
Reply By: bobsa - Monday, May 22, 2006 at 15:30
Hi Dave,
Ford 14" will fit.
Be aware that they genuine jayco has sunrasia steel rims, the same as the heavy duty rims on ford utes. If you are in Adelaide I have 3 genuine jayco rims that were from my 2003 freedom. The tyres need to be taken off of the rims as I will use them on my van. The reason I have them is I changed to 15" off road when I upgraded my springs. Regards Bob
AnswerID: 173981
Reply By: Wizard1 - Tuesday, May 23, 2006 at 11:38
I think I paid about $20 for it, then removed the tyre and fitted a used Dunlop LT I had.
If your only using it to move the van into a car port I see ne need for heavy duty rims bit I would avoid mags as they may bend.
Yes we have a 95 series GXL TD.
AnswerID: 174197
