Duel Battery Land Cruiser
Submitted: Friday, May 26, 2006 at 17:03
ThreadID: 34298 Views:2181 Replies:5 FollowUps:0
Hi all, I am thinking about fitting a duel battery to my 100 series Land cruiser V8 petrol, but just where do you put the power steering fuel reservoir? Any help and even a photo would be much appreciated, thanks Pete.
Reply By: Richard W (NSW) - Friday, May 26, 2006 at 17:51
Not sure about the petrol but I've got two starters up front in the diesel.
Just purchased a Remco 100AH for the rear replacing a 55AH Optima which wasn't up to the job.
Rebuilding the rear storage area.
Here's a link
AnswerID: 174946
Reply By: 100TD - Friday, May 26, 2006 at 18:42
i believe they move it in between grill and rad support then factory bkts can be used.Paul
AnswerID: 174958
Reply By: chook0402 - Friday, May 26, 2006 at 20:00
Hi peterjs,
Can I sugest you visit www.sidewinder.com.au/ for all the help you need. I have used Derek's products and they are first class.
AnswerID: 174970
Reply By: Member - Ivan (ACT) - Friday, May 26, 2006 at 23:27
Camera is out of action, so unfortunately no pics - but I disconnected the reservoir, chopped one leg off and then remounted it to the air cleaner mounting bolt (just on one bolt).
The only trick was the bend in the lower hose - I had to flip that so that the ends were swapped - and then it fitted perfectly.
I've got two 130 A/h deep cycles in there now.. No other mods required - except to mount the battery tray, and that was a simple affair.
AnswerID: 175020
Reply By: peterjs - Saturday, May 27, 2006 at 08:14
Thankyou to all for your help and advice, not in a hurry to fit it so will consider all options available, thanks again Pete.
AnswerID: 175042
