Advise needed clutch probs
Submitted: Tuesday, May 30, 2006 at 23:06
Johnny B Good
As posted yesterday the sarger cont on. As Nissan Australia claim to have done vigourous testing on my clutch they have found no fault with it and no undue wear. After a long 6 day wait Nissan have finally told me that they are not going to accept my warrenty cliam on my 04 Navara clutch.They say it is wear and tear. I do not tow big loads once a year maybe 4x4 is min
I am now stuck in
Perth ( I live in the Country) with my Navara in parts at the Dearler.
The dealer has told me that he can not longer help me with the claim and I now have to take it to Nissan Australia. I am unable to get home were I live, and getting no were with Nissan
Any advise would helpfull
Reply By: Member - Blue (VIC) - Tuesday, May 30, 2006 at 23:25
I feel for you Johnny... It seems like a very short life for a clutch and beyond pestering Nissan I don't really have any advice... FWIW, my Triton clutch has just rolled over 103,000km and still feels strong. It regularly tows near it's maximum rating, has done plenty off road and *gulp* my missus drives it regularly...
Good luck.
175773
Follow Up By: Johnny B Good - Tuesday, May 30, 2006 at 23:47
I don't understand? I went and got this ute under the expectation that it was reliable and was not going to start doing this. You no what!! after 60'000km + it dose a clutch in you have to really give it heaps for it to go. I work on the mines and those hilux utes get more abuse than
mine would. I long distance traval that is all I do and a small amount of 4x4
431844
Follow Up By: Member - Blue (VIC) - Wednesday, May 31, 2006 at 00:03
It doesn't make a lot of sense... I hope your perserverance(excuse my spelling, no google toolbar here at work) pays off.
431852
Follow Up By: Member - Bill S (NSW) - Wednesday, May 31, 2006 at 08:39
JohnnyBgood, Who diagnosed a Clutch problem in the first instance????? What makes me ask this is you mentioning that you had to give it heaps to go???
BILLS
431883
Follow Up By: Member - Pezza (QLD) - Wednesday, May 31, 2006 at 09:24
Don't worry about it Bill, a Futch won't fix his clutch problem, you can go back into your
cave.
Pezza
431892
Reply By: Leroy - Wednesday, May 31, 2006 at 09:06
Since the vehicle is in peices you could take the clutch somewhere else for a second opinion.
Leroy
175832
Follow Up By: Johnny B Good - Wednesday, May 31, 2006 at 09:51
the clutch was tessted by some expert clutch people they did not tell me who or what evidence they have
431895
Reply By: Nav 8 - Wednesday, May 31, 2006 at 11:28
If they found no fault with it and no undue wear how can they say it is wear and tear. I think you said in your first post that the clutch was slipping that was the case and there is no excess wear or damage on the clutch friction plate I would have to say it has to be the pressure plate at fault. There can not be any other reason for it to slip providing the flywheel surface is OK and it should be in a new vehicle. Clutches are not rocket science, it has to be a weak pressure plate. I remember back in the 80s the old MQs had a problem with clutch pressure plates being too weak, I would get a second opinion from a clutch specialist. Good Luck ,,,Nav.
175870
Reply By: mick - Wednesday, May 31, 2006 at 14:45
Which dealer in
Perth Johnny?
175905
Follow Up By: Johnny B Good - Thursday, Jun 01, 2006 at 01:35
morley city nissan
432098
Follow Up By: mick - Thursday, Jun 01, 2006 at 12:26
That surprises me! I've been dealing with them since new (03 Patrol) they have been great, I deal with Larry. Good bloke.
Mick
432150
Follow Up By: Johnny B Good - Thursday, Jun 01, 2006 at 20:06
Mick
You are write there, Larry is a Good bloke. He has a great knowledge of information and knows those cars backwards. You ask him anything he will know.
He has been helping me and has been great help. He all ways looks after me
All those nissan people go and see Larry
JOHN
432227
Reply By: brian - Wednesday, May 31, 2006 at 18:35
i agree have the pressure plate independantly tested costs almost nothing i have done previously and found it below specification,are you aware the clamping or clutch pressure is within a specified range from the manufacturer....sounds like yours may be below specification limits...ask for a copy of the specs from any good clutch repairer near you....compare with your test results or at least ask nissan for a written copy of any test results they may have on your clutch....
175955
Reply By: Member - Axle - Wednesday, May 31, 2006 at 19:09
Hi Johnny.
Not sure on the hydraulic set up on the nissan , That is( master cyl, slave cyl)
But had a experience with a truck once, where as the master cyl linkage had no freeplay there fore put slight fluid pressure on the slave cyl, which in time caused the clutch to half engage if you no what i mean. Just another area that can cause problems.
Hope all works out.
Axle.
175964
Reply By: Johnny B Good - Thursday, Jun 01, 2006 at 01:45
I will take you adivse and get the results i will also ask about the fly wheel and the plate thanks for you advise great help
176056
