Jackaroo Wide Body
Submitted: Wednesday, May 31, 2006 at 16:50
jhumphries
Can anyone help me how to identify if my Jackaroo is a wide body version or not. I am looking at a 2nd hand ARB bullbar off a 1999 Jackaroo and i want to know if it will fit my 2001 model.
Reply By: SimonW - Wednesday, May 31, 2006 at 16:56
Hi John,
Does you Jack have shift on the fly 4WD or locking hubs.
The shift on the fly was the wide wheel track version.
Cheers Simon.
175929
Reply By: nowimnumberone - Wednesday, May 31, 2006 at 17:56
pretty sure the wide track has plastic guard flares.
ring arb thats the easiest way.
175939
Reply By: grege7 - Wednesday, May 31, 2006 at 20:45
Hi John,
The easiest way to identify is the wide body has the number plate at the rear in the centre of the bumper bar,(down low), the previous model has the playe on the upper right rear door. Also the wide body has flaired wheel arches.
175995
Reply By: Outbacktourer - Wednesday, May 31, 2006 at 21:10
Yeah, all of that above is correct, although I think the shift on the fly may have come in earlier. Sure way to tell is check out where they have welded a couple of extra inches on either side of the rear axle tubes!!
176004
Reply By: Marc - Wednesday, May 31, 2006 at 21:59
ring holden with the VIN number
176024
Reply By: Member - Bradley- Wednesday, May 31, 2006 at 23:35
wide track - not wide body.
only difference in body is the fitment of plastic flares and plastic panel along sills.
176051
Follow Up By: Spudley - Saturday, Jun 17, 2006 at 23:09
Not all late model Jackaroo's are wide body. The 'standard' poverty pack sold to government departments etc had the same track as the older models.
Mine is a 2002 model year standard one and I enquired about the wide track etc and found that the U8 Jackaroo has the same track as the older L8. The same year model SE and Monterey have wide track. The special 'Nullarbor' is also wide track. All wide tracks had factory
wheels arch flares.
Regards....
Spudley
435305
