gearbox problems troopy 78 series
Submitted: Wednesday, May 31, 2006 at 22:58
ThreadID: 34490 Views:3616 Replies:4 FollowUps:8
I've been following the recent posts about gearbox problems in the troopy 78 series
i'm beginning to get worried about my MATE troopy
i,ve got a 2002 78 series and i've been hearing a klonk from underneath when i change gears, does that ring a bell with anyone.
any info appreciated.
skip
Reply By: Member - Phil G (SA) - Wednesday, May 31, 2006 at 23:02
If you have the 1Hz motor and R151F transmission then maybe yes!
AnswerID: 176045
Follow Up By: skippie - Wednesday, May 31, 2006 at 23:17
g,day phil g
it is a1hz motor
the r15f transmission i'm not sure about
i will find out,
thanks for you're help
FollowupID: 432089
Follow Up By: Member - Ian S (NT) - Thursday, Jun 01, 2006 at 09:19
Hi Phil,
With the troopy, just where do look to identify the gearbox type number? I know before I look that it will be the suspect one!!
Cheers Ian at Mt Dare
FollowupID: 432131
Follow Up By: Member - Phil G (SA) - Thursday, Jun 01, 2006 at 11:26
The little plate on the firewall should have the transmission number written there.
AFAIK all 78series 1Hz had the R151F gearbox.
TD and petrol versions had the H-series boxes, and didn't have the problem.
Toyota should be able to tell you whether you have a problem. They have advised two of my mates to get it fixed over the past year.
FollowupID: 432147
Reply By: The Rambler( W.A.) - Wednesday, May 31, 2006 at 23:06
From what I gather that is exactly the first signs of trouble---get it checked out as it is better to get it fixed now than in the "sticks"
AnswerID: 176046
Follow Up By: skippie - Wednesday, May 31, 2006 at 23:25
g'day the rambler
looks like i'm going to the bank before my next trip
skip
FollowupID: 432090
Reply By: Member - Ian S (NT) - Thursday, Jun 01, 2006 at 15:49
Skippie
I your other post which has now been deleted there was a reference to a repairer who supplied one piece drive shaft replacement for the offending 2 piece. Could you cut at paste (or resubmit that info) if you have it avaialble??
Ian @ Mt Dare
AnswerID: 176140
Follow Up By: skippie - Thursday, Jun 01, 2006 at 17:18
g,day Ian
unfortunately i haven't got the details anymore as the explorer team deleted
it for me at my request.
skip
FollowupID: 432192
Follow Up By: Member - Phil G (SA) - Friday, Jun 02, 2006 at 16:28
Ian,
The genuine Toyota replacement part is the stronger component.
And on the other thread, Don Kyatt was mentioned. Adelaide Truck and 4wd Spares on Regency Rd may be able to help you out as they are a Don Kyatt outlet. Might also be one in Alice Springs.
phil
FollowupID: 432416
Follow Up By: skippie - Sunday, Jun 04, 2006 at 18:57
g'day Phil
i'm in the beef city central queensland so it's a bit far to go there, we do have a toyota dealer here but he's a bit axi but there's other ways
thanks again.
skip
FollowupID: 432731
Follow Up By: Member - John (Vic) - Sunday, Jun 04, 2006 at 19:28
Why was the other thread deleted?
It was good info.,
FollowupID: 432738
Reply By: skippie - Thursday, Jun 08, 2006 at 18:30
g,day john
sorry i'm a bit slow with reply
the reason was that at the time
i thought two posts about the subject
wasn't the right thing to do
as the reply's were the same at the time
i asked if they could tell me how to delete one
unfortunately they took a while before they did
and i lost some very good information
if you contributed could you send it to me at skippie2094@msn.com
it looks as tho you think i should repeat the thread
i think i will,thanks for you're interest
skip
AnswerID: 177497
