FollowupID: 432615 Submitted:
Saturday, Jun 03, 2006 at 18:11
Redback posted:
I have a hand pump as well and a 12v pump, it's a Shurflo 60psi same pump thats in the Ultimate camper, they are around the $200 mark depending on where you get them, a good plumbing wholesaler would be the cheapest or the 12v
shop, aka All about 12volt here in
Sydney.
The best thing about the Shurflo is if you run your tank dry it won't damage the pump.
SHURFLO 8000 SERIES PUMPS
The Shurflo 8000 series is ideal for the toughest industrial applications requiring high pressure with flow rates up to 1.8 GPM (6.8 L/min) with low amp draw. Available with valving in a wide variety of elastomers, the 8000 series can accommodate a broad spectrum of chemical products. Count on the compact 8000 and the complete line of Shurflo pumps for long life, unmatched reliability and trouble -free performance.
