SECOND BATTERY
Submitted: Wednesday, Feb 26, 2003 at 10:45
ROBERT
HI ALL I HAVE A 1991 GQ FITTED WITH GAS WANT TO FIT A DUEL BATTERY SYSTEM UNDER BONNET TO RUN A ENGEL 40LT FRIDGE BUT I FIND THEIR IS NOT MUCH ROOM WHAT ARE MY OPTIONS
CAN ANYONE HELP PLS
Reply By: Truckster - Wednesday, Feb 26, 2003 at 11:30
It can be done easily
Dozens of GQs out there petrol and diesel with dual batteries... But yes it does get cramped.
Where to you live?? In
Melbourne, I recommend Alan at Outback Accessories in Seaford.. OUTSTANDING work...
Also look at
www.rotronics.com.au
www.arb.com.au
www.piranhaoffroad.com.au
www.tjm.com.au
Any 4wd
shop will be able to help you with this.
13972
Follow Up By: Robert - Wednesday, Feb 26, 2003 at 11:36
THANKS TRUCKSTER FOR YOUR QUICK REPLY I AM IN
MELBOURNE
WILL CHECK THOSE SITES YOU HAVE MENTIONED BECAUSE I HAVE GAS
FITTED THE LAST QUOTE I HADE WAS ABOUT $900.00 TO HAVE THE
BATTERY SYSTEM FITTED
8318
Reply By: Truckster - Wednesday, Feb 26, 2003 at 12:11
Who was that thru? What system was it too?
I went to a place on Wells Rd Frankston his price was insane! Went to piranha myself and saved 100's!
As I said Call Alan if your on this side of town. Say big Fat Cripple Bruce with the Big Black GQ told ya to call.... :D
13975
Reply By: ROBERT - Wednesday, Feb 26, 2003 at 12:17
THANKS TRUCKSTER SHELL DO THE PRICE WAS QUOETED FROM OUTBACK 4WD MECH AT BAYSWATER
13976
Reply By: tim - Wednesday, Feb 26, 2003 at 12:52
Set one up myself.
Battery sits opposite other battery where coil is.
Moved coil slightly drilled and bolted new battery holder in position and made bracket to keep tray flat.
Then i used a manual isolator connection between the two batteries so i could start of my auxillary without having to use jumper leads like you do with the electronic ones and mounted a switch on the dash.
But each to there own.
13982
Reply By: ROBERT - Wednesday, Feb 26, 2003 at 13:36
SOUNDS GOOD TIM NOT AS HANDY AS YOU I NEED TO FIND SOMEONE IN
MELBOURNE THAT CAN DO A SIMILAR JOB THANKS AGAIN
13990
Reply By: Voxson - Wednesday, Feb 26, 2003 at 14:54
Hi Robert... Because you have gas fitted you have no room in the passenger side rear for another battery....
I have just fitted a second batt in the rear of the car with success to run a 40 litre engel..
I have run the fridge non stop for 4 days with no startup and have not run it flat yet..
email me for info if you want...
voxson@bigpond.net.au
13992
Follow Up By: Robert - Wednesday, Feb 26, 2003 at 15:18
THANKS VOXSUN WILL EMAIL YOU SOUNDS GOOD
8331
Reply By: bonz - Wednesday, Feb 26, 2003 at 17:51
Robert,
When I had the gas on my GQ changed from barbeque gas to a decent impco unit the converter was fitted into the drivers side leaving the passeger side rear under the bonnet free for the second battery.
All the best
Bonz
14001
Reply By: diamond - Thursday, Feb 27, 2003 at 08:43
i also did the same as tim i have gq on gas i had to move the power steering filler rerouote air intake and that was about it it fits perfectly opposite the original battery i made my own tray cost about $20 i have a 3litre patrol so not sure if different set up in engine bay.
14030
Reply By: Craig - Saturday, Mar 01, 2003 at 19:31
As tim said , about moving the coil you simply turn the bracket the coil is on, around the other way , this moves the coil back abit then use a diesel battery bracket it will sit snuggly next to your radiator over flow bottle.Then you only have to work out what management system you want to use ,I just used a 90 amp solenoid .
( forgot to mention you will need to remove/reroute your air intake)
Good luck regards Craig.
14253
Follow Up By: ROBERT - Monday, Mar 03, 2003 at 09:41
hi guys thanks for your information have organised it to go under bonnet
by moving coil and reroute the intake hope it all works agaain thanks for all your replys robert
8612
