AnswerID: 181729 Submitted: Tuesday, Jul 04, 2006 at 09:00
Member - Captain (WA)
replied:
Hi Kingsley,
I had a rattle that appeared to be from my passangers airbag on my 2003 ST-S. It only appeared at certain rpm (1800-2200) and was not related to corrugations. However, I swore it was coming from my airbag/glovebox and reckoned I could "feel" it at times. Nissan tighten cables, lid etc... but after ~5 visits to Nissan they finally found a broken weld on an inner guard bracket after removing my
snorkel, inner guard lining and other bits and pieces. Turns out a spot weld had failed and was vibrating at certain frequencies.
While this may not be your problem, at least its somewhere else to look. But be aware that Nissan has replaced several passenger airbags for the exact rattle you are describing. I thought my problem was the airbag until they found the true cause. Don't accept Nissan's "never heard of that before" stock reply to all problems, its must be standard Nissan training to "deny, deny deny". Check out old Nissan Patrol forums on Yahoo, it was a hot topic for a while and seems like there was a bad batch of airbags in 2003.
Captain
 Click Image to Enlarge |
| Its not what you drive, but how you drive it!
Reply 2 of 5
