AnswerID: 181866 Submitted: Tuesday, Jul 04, 2006 at 22:22
geocacher (djcache)
replied:
I have been using VoIP for a while now as my primary phone service.
I use myfone.com.au and a Netcomm V300 VoIP box to handle the calls.
The V300 is an interesting bit of gear in that it contains a phone switching circuit.
The normal cordless phone plugs into one socket, the phone line out to the wall via a filter plugs in to a double adapter with the line to the ADSL modem.
Incoming calls to our normal land line number come in and get switched by the v300 to the phone.
Outgoing calls from the phone get routed out via the ADSL (broadband).
If the broadband is down this is detected by the v300 and the call just gets transparently routed out by the v300 to the standard land line (at land line rates via Telstra or whoever your home phone is with.)
Importantly as mentioned above 000 calls also go out by the land line. I too work in Ambulance dispatch and understand the importance of CLI data. With the v300 a 000 call should use your normal phone line and transmit the data it needs. It should also default to the land line in a no power type situation.
You can manually choose the land line too by pressing ## and dialling a number.
The v300 has ports for the computer to plug into and will slow your internet to maintain voice quality if one of the kids is in the study downloading music or movies while you are on the phone.
My estimate based on a couple of months use is that this will save us about $1000 a year. The previous call usage component of our bill was around $90 a month. Now it's about $15. (Made up of 12.5cent untimed local calls to anywhere in the country.) Calls to other myfone users are free so if you get your family all in on this you could reduce it further.
Also if you have kids at uni in a major city and you are paying their phone bill for them to ring you at home, for $10 a month you can nominate a major centre (eg. Melb Geelong Ballarat etc in Vic) and get a number that people in that centre can ring to call you. They only pay for a regular local call and myfone route the call in their system to you where ever you are.
VoIP is one of the single biggest reasons the big Telcos are projecting negative growth - and why I won't buy shares in Telstra.
Get on board - $1000 buys us about 7000km worth of fuel :o). It's great.
 Click Image to Enlarge |
| Have you tried geocaching yet?
www.geocaching.com |
Reply 11 of 16
