Map of Brisbane area
Submitted: Wednesday, Jul 05, 2006 at 17:24
Member - Troll 81 (QLD)
Hi Team
Can someone pretty please email me a detailed map of
Brisbane street level that I can test with oziexplorer. I am just mucking around to learn the program and I need a map. I will buy some maps once I have worked out the program
cornelb@netspace.net.au
Reply By: Trevor R (QLD) - Wednesday, Jul 05, 2006 at 17:30
One of
Maroochydore on it's way.
Hope it is what you wanted.
Trevor.
181963
Follow Up By: Member - Troll 81 (QLD) - Wednesday, Jul 05, 2006 at 17:34
Thanks Trevor
I was hoping to get one of
Brisbane to see if it will pin point my position where I am at the moment. I will see if I can get some of that ozimapgrabber program
438307
Reply By: Member - Andrew (QLD) - Wednesday, Jul 05, 2006 at 17:53
How about a large brisvegas one including all suburbs and their major streets.....good for learning Ozi :-) (note: 4+mb)
Go here ==> www.jaiper.com/files/Brisbane_Suburbs.zip
181969
Reply By: Member - Coyote (SA) - Thursday, Jul 06, 2006 at 08:30
call me silly... Ok... I asked for it... but there seems to have been a few comments on ths and other threads about using Oziexplorer to navigate streets.. Is there a new version ouit or am I just meissinga feature of Ozieplorer??
Does Ozi now have street navigation ? Or is it just that it's being used like a paper map in that all it does with moving map is show your location on the map.
I guess whqt I'm asking is, does it work like street mapping progrmas where you can select addresses, 'lock to roads' etc so if thereis a lsight error it doesn't show you driving through buildings etc and what about turn by turn prompts?
Surley if it is just showing yu as a dot on a mpa, this is a dangerous way to travel given that you would need to be practically watching the map at every turn.
Please enlighten me as to how Oxiexplorer works for street navigation? Cheers
182079
Follow Up By: Member - Andrew (QLD) - Thursday, Jul 06, 2006 at 11:04
it doesn't work....and never will with a raster style mapping program. All the routable/street guidance programs use vector data to compute the best (?) route to follow along streets.
There is nothing difficult with using a raster map to see where you are and work out in your mind which way to turn. The vector based programs just eliminate the "mind" in the equation. :-)
Just be aware that we are not saying the driver is necessarily using the program to navigate whilst driving. That's why we have passengers :-)
438458
Follow Up By: Member - Andrew (QLD) - Thursday, Jul 06, 2006 at 11:05
sorry, my mistake.....forgot to call you silly as requested ;-)
438459
Reply By: Pajman Pete (SA) - Thursday, Jul 06, 2006 at 17:10
UBD City Streets V3 will operate perfectly in Ozi and includes all capital cities,
Wollongong,
Newcastle and the blue mountains.
I am using it in
Darwin right now.
It must be version 3.
$60 at the RAA in SA
Pete
182151
