Dual battery Set up 03 Patrol
Submitted: Thursday, Jul 06, 2006 at 19:15
corny
Hi All
I am looking at getting dual batteries for a 03 patrol. I have been quoted roughly $800 by a 4wd store this includes fridge socket wired into back of car but no battery. Does this sound about right? Would i be better off going to a Auto Electrician. Only want a basic set up that isolates once engine turned off??
All help apreciated
Corny
Reply By: Notso - Thursday, Jul 06, 2006 at 19:19
Sounds expensive. especially with no battery.
I did my own and bought all the bits including battery and battery box from ARB. Cost about $400.00. Took about two hours max.
182171
Reply By: Member - jeff M (SA) - Thursday, Jul 06, 2006 at 19:29
I also think this sound a tad expensive.
I just fitted a battery tray today from oppisite lock $127, I will get the auto sparky to do the rest I should get out of it for around $500 all up I recon.
Tankman
182173
Reply By: Steve - Thursday, Jul 06, 2006 at 20:06
You dont say where you are !!! (which makes one hell of a difference !!... ) If in
Sydney send your number and I will give you a contact that will do it all for a fraction of that quote !!...a professional Motor Electrician who does this stuff all day every day !! its not difficult really ,, ...just knowing and or finding the person who does if for a living is the hard part !!!
182178
Reply By: Member - BUNDY BOY (WA) - Thursday, Jul 06, 2006 at 20:24
hay corny ....gettin one fitted over the weekend from local 4x4
shop.....$525 fitted with battery...arb thats with all the hassle of moveing power steer filler and makkein room for it .........think you should do some more shoppin around.........happy shoppin.............bundy
182181
Reply By: Truckster (Vic) - Thursday, Jul 06, 2006 at 21:32
Tray $100ish 5 screws to fit usually
Battery $120 usually 2 clamps and 2 terminals.
Solinoid $100-700 depends on the type, but could be worth paying to fit.
Extra fuse panel $30 2 screws to fit.
Run the wires to the back of car after removing trim, and other bits (plenty of labour for them, or a nice day to take advantage and clean the carpet while yoru at it and run wire yourself)....
drill hole in back for fridge plug,
solder 2 bits of wire to fridge plug and 2 to the fuse panel...
which state are you in, and what specs on items were you given?
EG What battery, what solinoid, what tray..
give more info on what your having fitted will tell if your being reamed.
182191
Reply By: Chris & Jody (Golden Bay) - Friday, Jul 07, 2006 at 07:51
Corny,
I have to agree with all that $800 sounds a bit over the top especially with no battery supplied. I installed a power outlet in the back of my GU a couple of weeks ago for about $120.!MPG:8!
It took about 2 hours to run the new 6mm cable from my second battery through the car to the back. I got all the know how and help from these pages.
Do the research and get more quotes!
Good luck.
Chris
182250
