Wiring a UHF radio
Submitted: Saturday, Jul 08, 2006 at 14:45
ThreadID: 35620 Views:18832 Replies:3 FollowUps:8
Hi, I have a UHF radio that I want to wire up in my Jeep. Is it best to wire it straight to the battery, or find a power source behind the dash? How do I wire the negative wire to the ignition so that when I turn the key off, the UHF turns off as well?
Reply By: Member - qld_bushpig - Saturday, Jul 08, 2006 at 14:51
I wired mine directly from second battery with inline fuse. Can leave it on while engine is not running.
AnswerID: 182413
Follow Up By: hamish75 - Saturday, Jul 08, 2006 at 15:00
Thanks!
FollowupID: 438836
Reply By: disco1942 - Saturday, Jul 08, 2006 at 14:56
Wire it directly to the battery. Insert an in line fuse close to the battery positive.
If you wish to control the radio by the ignition switch insert a relay in the positive line after the fuse. Find a wire that is hot when the switch is in both the accessory and run positions. Use this source to energise the relay.
AnswerID: 182414
Follow Up By: hamish75 - Saturday, Jul 08, 2006 at 15:02
Thanks for the advice, will give that a shot.
FollowupID: 438837
Reply By: Member - Cherokee (NSW) - Saturday, Jul 08, 2006 at 15:09
Hamish
I did mine straight behind the cigarette lighter - does the job...
AnswerID: 182417
Follow Up By: Member - Cherokee (NSW) - Saturday, Jul 08, 2006 at 15:25
Are you in Sydney by any chance? I'd be happy to help you do it.
FollowupID: 438840
Follow Up By: hamish75 - Saturday, Jul 08, 2006 at 15:43
No, I am in Melbourne, but thanks for the offer!
FollowupID: 438841
Follow Up By: Member - Cherokee (NSW) - Saturday, Jul 08, 2006 at 15:51
Just grab a test light from an autoparts retailer like Supercheap Auto - $2 I paid for mine. Pull the cigarette lighter out, and use the test light to find the positive wire - then earth it out behind the lighter somewhere and you should be sweet.
FollowupID: 438842
Follow Up By: VK3CAT - Saturday, Jul 08, 2006 at 18:55
Any 2 way radio equipment should be wired direct to the battery via a suitable sized cable and an inline fuse close to the battery. (Fit a fuse block or similar for additional connections) The negative cable should be taken back to a negative junction point close to the battery but not direct to the battery negative terminal. (Avoid earth loops)
The radio should also have inline fuses on both positive & negative lines.
The reasons for this is to avoid voltage drop and interference with / from other appliances. Any fault on the main vehicle electrical system won't be able to use the radio negative cable as an alternate path - resulting in burnt out cabling or radio!
It is useful to monitor the UHF CB radio without having to have the key in the ignition.
Keep all cabling away from ignition sources & heat.
Cheers Tony.
FollowupID: 438856
Follow Up By: hamish75 - Saturday, Jul 08, 2006 at 19:12
Hi Tony, Sounds like great advice. The cable that I was supplied with (GME Electrophone) only had a fuse on the positive cable, do you recomend fitting one to the negative as well??
FollowupID: 438859
Follow Up By: disco1942 - Saturday, Jul 08, 2006 at 20:12
The old 2 way radios had a fuse in each power line. This were a cheap method of disconnecting the power when removing the radios for service – much cheaper than using a Jones plug. Looks like the practice still lingers even though 2 fuses are no longer required
FollowupID: 438861
