How to remove wax build up in gas system
Submitted: Saturday, Jul 08, 2006 at 23:37
cipher
Hi every one,
just wondering if any has any experience with cleaning out the wax build up from poor quality gas in converter?
If anyone know how to get the wax out and give her a good old clean out and what not to do etc etc etc
Would be a huge help
Justin
Reply By: Member - BBB - Sunday, Jul 09, 2006 at 06:39
Dont play with Gas go to a licenced Gas Fitter
BBB
182510
Reply By: bucky - Sunday, Jul 09, 2006 at 06:53
Hey Justin
Change to a different dealer, But I've never heard abouot the wax problem though?? Lines or engine ???
10-12 years back I was using Safeway Gas, in my 2003 Commodore, because it was the cheapest, one day they ran out..
To my disgust I went across the road to an " Independant " dealer and got an extra 70-80 km for the same amount of gas, and about 10% lift in power, it actually works out cheaper than Safeway because they sell lighter fluid.
I was also told, by a mechanic, that in order to keep the engine running better, change the plugs to a gas plug .. if my memory serves me correct they were Bosch HR7DCY plugs, ( or similar sounding name ), and change them regularly ( 20,000 km )
I have since brought a new Navara 2003 ,, 3.0 TD, and use Safeway fuel only when I cannot get anything else
Cheers Mate Bucky
182512
Follow Up By: Old Scalyback & denny - Sunday, Jul 09, 2006 at 18:00
thers always something besides safeway although depends on where you are never had problems from pt
augusta
steve
438962
Reply By: Kiwi Kia - Sunday, Jul 09, 2006 at 07:49
I have not seen wax but I do see a rather viscous oil. Just turn off the gas, open a drain bolt at bottom of converter and let it dribble out.
182515
Follow Up By: cipher - Sunday, Jul 09, 2006 at 08:51
thanks kiwi kia..
Do i need to take the bolt out completely or just losen it?
Justin
438912
Reply By: Kiwi Kia - Sunday, Jul 09, 2006 at 13:38
Some of the converters have a small (about 6mm) bolt and I have seen others about 20mm. You have to take them right out but make sure you have turned the outlet from the gas cylinder off first just in case the converter demand valve sticks open. I have usually got about a tablespoon of oil out of them. Fixes all sorts of running problems so I always try this first.
182545
