Battery charging
Submitted: Sunday, Jul 09, 2006 at 16:19
ThreadID: 35659 Views:2170 Replies:3 FollowUps:3
"Please explain" Now I either read/was told that charging a battery on a concrete floor would damage the battery, I`v probably been guilty of that at some stage plus blowing the top off a couple to boot, now apart from the obvious damage caused by my inattentiveness I can`t say I`v seen any evidence of my having charged one or two on a concrete floor. What damage does it do to the battery & why?????
Cheers Ron.
Reply By: Mike Harding - Sunday, Jul 09, 2006 at 16:23
An old wives tale.
AnswerID: 182563
Follow Up By: Member - Cruiser (NSW) - Sunday, Jul 09, 2006 at 16:44
My old wife never told me that tale, but she did tell me a few times where to go, until one day I took notice and went.
FollowupID: 438952
Follow Up By: disco1942 - Sunday, Jul 09, 2006 at 17:51
Mike – not completely “old wives tale.” This was the situation with the old rubber loaded cases. Just does not apply to the modern plastic ones.
FollowupID: 438960
Reply By: Derek from Affordable Batteries & Radiators - Sunday, Jul 09, 2006 at 17:51
Mike is right.
(Hey that rhymes)
Old batteries long ago would weep and short out to the concrete and the cold floor would also lower the capacity.
No worries with new batteries.
Regards Derek.
AnswerID: 182575
Follow Up By: Derek from Affordable Batteries & Radiators - Sunday, Jul 09, 2006 at 18:13
Found this info...
Flooded Lead Acid Battery Storage
Trojan: Periods of inactivity can be extremely harmful to lead acid batteries. When placing a battery into storage, follow the recommendations below to insure that the battery remains healthy and ready for use.
NOTE: Storing, charging or operating batteries on concrete is perfectly OK. The most important things to avoid:
Freezing. Avoid locations where freezing temperature is expected. Keeping battery at a high state of charge will also prevent freezing. Freezing results in irreparable damage to battery's plates and container. [Freezing can happen between -19 F (40% charge) and -98 F (fully charged)]
Heat. Avoid direct exposure to heat sources, such as radiators or space heaters. Temperatures above 80° F accelerate the battery's self-discharge characteristics.
Step by step storage procedure:
1. Completely charge the battery before storing.
2. Store the battery in a cool, dry location, protected from the elements.
3. During storage, monitor the specific gravity (flooded) or voltage. Batteries in storage should be given a boost charge when they show a 70% charge or less. Completely charge the battery before re-activating.
FollowupID: 438966
Reply By: Kiwi Kia - Sunday, Jul 09, 2006 at 17:52
It's the concrete floor that gets damaged - not the battery.
As the battery charges gas bubbles come to the surface inside the battery and burst on reaching the surface of the electrolyte. Small droplets of acid drift away and are deposited on any nearbye surface. The alkalyne cement reacts with the acid and breaksdown causeing holes to appear in the concrete.
AnswerID: 182576
