Nissan "no airbag" glovebox
Submitted: Monday, Jul 10, 2006 at 00:07
ThreadID: 35672 Views:2891 Replies:7 FollowUps:9
I said to a guy last week I would post my pics of the new glovebox where the airbag isn't in my GU. It could still do with some tidying up but it now looks pretty good and secure with the key lock the standard one doesn't have.
Reply By: Member - Wim (Qld) - Monday, Jul 10, 2006 at 07:03
Hi John
Looks the goods. Did you make it?
Camper setup
July 2012 - Hay River & Binns track
VKS 737 Mobile 0091
Selcall 0091
AnswerID: 182638
Follow Up By: Member - JohnR (Vic)&Moses - Monday, Jul 10, 2006 at 08:22
Yes Wim, though the internal boxing is aluminium. I made the template for it and had it made to slide in to place. I didn'[t weld the aluminium either - actually Member - Sharyn M's hubby did that for me. I did the cutting out, hinging, lock fitting and messy siliconing that is in the process of cleaning up.
Hope things are all well there mate, best wishes to Judy too...........
FollowupID: 439063
Reply By: Gramps (NSW) - Monday, Jul 10, 2006 at 07:34
Good stuff John. Well done.
AnswerID: 182641
Reply By: Member - Troll 81 (QLD) - Monday, Jul 10, 2006 at 07:57
Very nice mate, when can I bring mine down?
AnswerID: 182644
Follow Up By: Member - JohnR (Vic)&Moses - Monday, Jul 10, 2006 at 08:24
Reckon the drive down would make it an expensive glovebox mate. Takes a bit of fiddling though
FollowupID: 439065
Reply By: pprass - Monday, Jul 10, 2006 at 12:45
Excellent John! I was going to do the same thing so that I could insert my 8" Lilliput touch screen in there, which is about 12cm high and about 15cm wide. I was thinking of a sliding rail set-up so that I could pull it out and then swing it up horizintally when in use. Then swing it down vertically and slide it back into the storage area when not in use.
Do you think that a 12x15 cm screen (lying vertically ie flat) would fit in there? Also how do you start by taking out the panel to begin with?
AnswerID: 182686
Follow Up By: Member - JohnR (Vic)&Moses - Monday, Jul 10, 2006 at 13:27
Peter I should probably not made a flat floor to the box and allowed deeper section before the cross bar behind the dash. That would have allowed greater volume perhaps.
You need to remove the glove box which is about 8 screws to get access to the back of the panels. Using a short Phillips screw driver undo the six screws round the perimeter of the facia panel or future glove box lid.
I used an angle grinder to cut the edge of where the internal of the box will be and a key hole saw across the bottom of the box to cut off a trim edge across the front, jutting toward the passenger. There is a piece of steel that goes across the opening from side to side too that takes the screws for the glovebox (lower) catch. I had to rebend it the opposite way to allow it to be screwed to the floor of the new box. It is only thin gauge.
I was thinking of putting my thin laptop in the box on an angle, but more inclined to think it would be better in behind the radio and UHF putting those into a roof compartment. I liked what I saw of that post a month or so back that Truckster put up. Screen set back in there with mouldings.
FollowupID: 439125
Follow Up By: Member - JohnR (Vic)&Moses - Monday, Jul 10, 2006 at 13:33
Meant to say that round the front of the new box is the air feed pipes to the front vents. It would be easy to get air flow there to cool all sorts of hardware. The box isn't as big as I had hoped, but a considerable improvement on the standard one taking additional items with a lock. The lock was about $9 I think. I used some more aluminium on the face of the box lid cutting back the screws and their mounts on the new lid.
FollowupID: 439128
Reply By: Old Scalyback & denny - Monday, Jul 10, 2006 at 20:47
gooddaay john
hows things
just looking at your pictures does this mean you have 2 boxes now with the lower catch on the lower sied of the top box or is it 1 large unit
steve
AnswerID: 182801
Follow Up By: Member - JohnR (Vic)&Moses - Monday, Jul 10, 2006 at 21:30
Yep Steve, have two glove boxes one above the other, even one you can lock and see into when it is open.
Hows Denny by the way? Hope you are well too..........
FollowupID: 439285
Reply By: Old Scalyback & denny - Tuesday, Jul 11, 2006 at 20:53
goodday john
we are both good only 2 sleeps and we have 4 weeks off and looking forward to the break
we are watching the weather for the simpson fairly closely as we have 1 week in merimbula come back repack truck with the camping gear and head up towards and across the simpson ,innamincka and surrounds
after seeing your glove box i might try something with ours when we return it looks like a good place to plant bits and pices away from view
steve
say goodday to heather for us
AnswerID: 183016
Follow Up By: Member - JohnR (Vic)&Moses - Tuesday, Jul 11, 2006 at 21:52
Have a great trip both of you. I won't really mind if you get rained in on the Simpson crossing, so take plenty of food, it would be good for Australia, widespread rain. Perhaps wet there before you go be better mate.
Have fun
FollowupID: 439525
Reply By: drifta - Tuesday, Jul 11, 2006 at 21:58
Thats a neat job. Thanks for posting it. I was hoping to find a lock you can open with or without the key that does not protrude from the box. I'm still looking. It's the mighty velcro for mine for now but will finish it properly when I return from my trip.
Drifta
AnswerID: 183041
Follow Up By: Member - JohnR (Vic)&Moses - Tuesday, Jul 11, 2006 at 23:09
Thanks mate. The reason to put the lock there was easier to reach from the drivers side if you wanted, but also that corner sat out slightly more and the lock holds it in.
The depth of the lock is just great enough to get past the floor of the lid too, I have to cut the screw mounts back just a bit with plyers and shorten the screews slightly too. The key does come out and it looks like a bought one with just the lock in there. Will probably blacken it. The silicone needs that too.
FollowupID: 439564
Follow Up By: drifta - Wednesday, Jul 12, 2006 at 10:50
I'm glad you said the corner stuck out more on that side I spent an hour trying to figure out why mine did that. It must be the same with others so I can stop looking now. It's not much different but enough to catch my interest and frustrate me when I looked at it.
Drifta
FollowupID: 439635
Follow Up By: Member - JohnR (Vic)&Moses - Wednesday, Jul 12, 2006 at 11:06
Drifta. I liked the sort of catch too but it is something to do with the hinging that it sticks out more that side I think. It doesn't look at all out of place being there either. I didn't like the catch on the glovebox on pictured outer limits.
As for disclosing the lid stuck out that side. LOL, I guess I am a relatively straight shooter. Not that I disclose all. ;-)
The new lid is a pretty close fit all around. I have given the catch a bit of a tweak and twist to make sure it catches nicely, holding it in place.
FollowupID: 439640
