GPS units????
Submitted: Monday, Jul 10, 2006 at 14:21
ThreadID: 35691 Views:2870 Replies:7 FollowUps:10
Hi all,
I am looking at purchasing a GPS unit in the next few months and currently looking at the Magellan Explorist 500 or 600.
I am after something that can be connected to a PC, trip logs uploaded and downloaded all in a small unit. To me, these Magellan units seem OK. I looked at the XL, but I think this would be too big. I want to be able to use it in the car, take it out and use it walking, boating etc.
What are some peoples experience with these or other units? Any problems with using them?
Reply By: Member - Craig D (SA) - Monday, Jul 10, 2006 at 14:28
Have a look at a Garmin Map60C as well. It is a small unit, nice bright screen, great battery life, waterproof, etc. And I do use mine for bushwalking to log tracks when its not mounted in the car. Nothing against Magellans just like the Garmins.
AnswerID: 182704
Follow Up By: madcow - Monday, Jul 10, 2006 at 14:42
Just bought a gpsmap60cx and it's great! $480.00 from the states delivered. Loaded T4A onto it and could not be happier!!
FollowupID: 439143
Reply By: Member - Coyote (SA) - Monday, Jul 10, 2006 at 14:28
I think you should give Johnny Appleseed GPS in Brisbane a call. They are always very helpfull and can give you the pros and cons of all of the types etc..
I did and ended up with a Garmin GPS Map 60C It is handheld, color, day/night readable, water proof can be used for turn by tunr street navigation (not voice but beeps and on screen directions) and can also e used for marine and/or cross country navigatio all in a compact unti just a little fatter than a mobile phone.. There is now a Garmin GPS 60 CS which has a built in compas (only usefull if you are standing still and want to know what direction it is pointing in, otherwaise any other GPS can tell you which directio nyou are moving in) and it also has a removable memory card..
Good luck.. I jave mine mountedonthe dash and is excellent, then when I want to go walkabout I can easily just pick it up and the batteries kick in straight away and off I go..
AnswerID: 182705
Reply By: Member - Coyote (SA) - Monday, Jul 10, 2006 at 14:39
I think you should try calling Johnny appleseed GPS in Brisbane.. (just Google search and they will stick out) They are gresat.. you can tell them what it is you want to do and they can walk you through the pro's/cons of eachbrand/type etc.
FWIW, I bought a Garmin GPS MAP 60C.. It has a color display, backlight for night, battery/car power, can be used for street Nav/ marine Nav/ Cross country Nav. It's water proof, rugged and only a bit larger than your mobile phone. I have mine mounted on the dash for street nav, then when I go croass country it works just as well and I can unplug it from the car in 1/2 a second and go on foot. there is even now topo maps for it, albeit a rather large and usless scale for foot navigation but they are getting better and better.
Garmin now also has the GPS MAP 60CS which has a compass built in so you can tell which way it's pointing when you are standing still (without this you must be moving to be told direction) - I still haven't worked out why you would really need this feature. it's not like it has sighting cross hairs so you could shoot a bearing to a feature or something.. just saves you from taking 2 steps in the worng directio becuase as soon as you move any other GPSwill be able to tel lyou wich way you are going.. It also has a removable meory card.
Good luck
AnswerID: 182708
Follow Up By: Member - Coyote (SA) - Monday, Jul 10, 2006 at 14:41
sorry all about the double post.. I thought I had accidentally deleted the first lot..
Geez.. like I dont do enough typing for work I end up doing non work stuff twice.. geez I'm a glutton for punishment. What can I say.. OOOPS
FollowupID: 439141
Reply By: Member No 1- Monday, Jul 10, 2006 at 14:49
what ever you get make sure you get UTM ....if your like me you cant understand...(well dont want to) longitude and latitude ...a lot easier using utm with a map
AnswerID: 182713
Follow Up By: Des Lexic - Monday, Jul 10, 2006 at 15:12
So your still alive then!!
FollowupID: 439149
PS Cos I was sooo looking forward to the wake.
FollowupID: 439151
Follow Up By: Member - Andrew (QLD) - Monday, Jul 10, 2006 at 15:32
yeh, don't be conned with those models that don't contain UTM.......i found it was hard to upgrade to the UTM option without voiding warranty.
FollowupID: 439156
Follow Up By: Member No 1- Monday, Jul 10, 2006 at 16:23
i dont think she has opened that email yet?...not like her to not say anything ....
could she be planning something very sinister?
FollowupID: 439175
Reply By: arthurking83 - Monday, Jul 10, 2006 at 18:59
If you definitely DON't want the large screen of an XL then look to the Garmin (map60 Cx)...
I can't recommend Magellan anymore due to their lack of customer support!!
While the explorist is a good GPS, and you may enjoy it for years....Magellans current mentality towards customers that purchased a GPS only 6 months (or so) ago...is..... well..... bad luck!....now you don't get anymore map updates!!
The Meridian series was still a supported model up till about Dec-Jan, then they decided that as of Dec2005, it isn't going to be supported any more.....(with many thousand out in the wild!!)
Now NextDestination sell newly released maps (of NZ and Marine Charts) only for the explorist!
What's to say they don't suddenly decide that the explorist is suddenly no longer supported (as of Jul2006!!) and they decide it's time for people to upgrade to the next model????
Magellan? steer clear of them ;)
ps. I was once a Magellan fanboi!......not any more! **mad**
AnswerID: 182760
Reply By: Joombi - Monday, Jul 10, 2006 at 18:59
I'd go the Magellan Meridian series, they are getting cheaper & are still a great unit, the only thing that has changed is bells & whistles in newer models, they all give you the same result, GPS technology has not changed in more than 10 years
AnswerID: 182761
Follow Up By: Member - Andrew (QLD) - Monday, Jul 10, 2006 at 19:39
i don't know about that :-) ....still remember the single-channel receivers (not these modern 12-20 parallel channel beasts), Internal memory battery, Selective Availabilty ON, non-mapping, non waterproof, pixelated LCD screens, 4 AAs, etc
Apart from that, they probably haven't changed that much ;-)
FollowupID: 439216
Follow Up By: The Explorer - Monday, Jul 10, 2006 at 19:52
Yes use one of those Magellan Nav 5000s - 6 AA's lasted 4 hours! It would track 4 sats (one at a time) ..if it lost one during initial pick up it had to start all over. With respect to Meridians and eXplorists there is however little difference in positioning capabilities (if any). Colour screens (that you can actually see in daylight) are biggest advance..IMHO.
FollowupID: 439223
Follow Up By: Rick (S.A.) - Monday, Jul 10, 2006 at 20:59
G'day Greg,
You may recall we have swapped notes before..........and I'm still doing the same sortsa things. Have just become an inaugural member of the " Freinds of the Mound Springs", so will look forward to more remote country trips & work in the years to come.
Anyway, just been reading up on the explorer you quote on your EO signature.
It occurred to me that most people refer to him as Peter Warburton, or Colonel Warburton, or Police Commissioner Warburton. I certainly have been.
I now have just become aware that his name is actually Peter Egerton-Warburton. That is, his surname is a hyphenated one. So for years I have been refrerring to him by half his name! Hope the old bugger forgives me.
Thought you may be interested in that trifling detail..............
FollowupID: 439266
Follow Up By: The Explorer - Monday, Jul 10, 2006 at 21:19
Hello - didnt really occur to me - even the introduction to his journal gets a bit confusing with respect to his name ..sometimes Colonel Warburton...sometimes Colonel Egerton Warburton (though they never seem to use a hyphen). Also one trouble with the EO signature is you are limited to 100 charaters..so explorers with hyphenated names can cause issues by taking up valuable space.
Have fun at the mound
FollowupID: 439278
Reply By: Member - andrew B (Kununurra) - Tuesday, Jul 11, 2006 at 08:14
Although I have only Garmin experience, they seem to be a great unit. I bought a gps76 a number of years ago before the gps 76 came out - which has 8 times the memory and is a better unit. The best thing I can say about my unit is that it still works. I live in the tropics, it can spends days mounted on the dash of the boat or the car, waterproof AND floats - I use it a lot in the water for crab pots etc, and its no good having a gps working hapily in a few metres of water where you can't get it back.
Basically I treat it badly and it still works, and I'm really good at breaking things!
Cheers Andrew
AnswerID: 182877
