Things your mobile phone can do.
Submitted: Monday, Jul 10, 2006 at 14:35
ThreadID: 35692 Views:3253 Replies:10 FollowUps:6
We all know that when our mobile goes ring ring there is usually someone on the other end of the invisible bit of string that we can talk to.
Got the following in an email and was wondering if it really works.
THINGS YOU NEVER KNEW YOUR CELLPHONE COULD DO
There are a few things that can be done in times of grave emergencies. Your mobile phone can actually be a life saver or an emergency tool for survival. Check out the things
that you can do with it:
1) Subject: Emergency number
The Emergency Number worldwide for Mobile is 112. If you find yourself out of coverage area of your mobile network and there is an emergency, dial 112 and the mobile will search any
existing network to establish the emergency number for you, and interestingly this number 112 can be dialed even if the keypad is locked. *Try it out.*
2) Subject: Have you locked your keys in the car?
Does you car have remote keys?
This may come in handy someday. Good reason to own a cell phone:
If you lock your keys in the car and the spare keys are at home, call someone at home on their cell phone from your cell phone. Hold your cellphone about a foot from your car door and have the person at your home press the unlock button, holding it near the mobile phone on their end. Your car will unlock. Saves someone from having to drive your keys to you. Distance is no object. You could be hundreds of miles
away, and if you can reach someone who has the other "remote" for your car, you can unlock the doors (or the trunk).
Editor'sNote: *It works fine! We tried it out and it
unlocked our car
over a cell phone!"
3) Subject: Hidden Battery power
Imagine your cell battery is very low, you are
expecting an important call and u don't have a charger. Nokia instrument comes with a reserve battery. To activate, press the keys *3370#
Your cell will restart with this reserve and the
instrument will show a 50% increase in battery. This reserve will get charged when u charge your cell next time.
Has anyone ever tried any of the above and found them to work?
Reply By: old mate - Monday, Jul 10, 2006 at 14:37
1. True
2. Utter Crap!
3. Don't know, will give it a go.
AnswerID: 182707
Reply By: Darren C - Monday, Jul 10, 2006 at 14:43
Certainly hope number 2 is crap....or at least I hope that insurance companies will accept this reason if my vehicle is stolen and I tell them I had locked the car!
AnswerID: 182710
Reply By: Member - Coyote (SA) - Monday, Jul 10, 2006 at 14:47
No.3 worked on my Nokia... am curious about the lock thingy.. I thought the locks worked of a radio transmission, I'm no techno wizz, but I guess it work work if the locks were operated by an sonic tranmission rather than radio ... I doubt that would work in most modern cars.. can only try I suppose.
AnswerID: 182711
Reply By: Member - Andrew (QLD) - Monday, Jul 10, 2006 at 14:52
1. Not necessarily true in 100% of cases....however is generally correct (not necessarily required to work on CDMA style networks worldwide, some old phones may not work etc etc)
2. Might want to get rid of the editor's note!
3. Changes my speech codec on nokia....therefore load of garbage.
sounds like more spam floating around the net :-)
AnswerID: 182714
Reply By: Mike Harding - Monday, Jul 10, 2006 at 14:58
As mentioned above; number 2 is just plain wrong.
No. 3
The code *3370# does the following on the 8110 and probably other Nokia phones too:
Model Number:
8110
Code Title:
Enhanced Full Rate Codec (EFR)
Code:
On: Enter *3370# and EFR will be activated after a reboot of the phone ( consumes more power )
Off: Enter #3370# and EFR will be switched off after a reboot of the phone.
Code Description:
Enhanced Full Rate will give you much better sound quality when you enable it. The new Enhanced Full Rate CODEC adopted by GSM uses the ASELP (AlgebraicCode Excitation Linear Prediction) compression technology. This technology allows for much great voice quality in the same number of bits as the older Full Rate CODEC. The older technology was called LPC-RPE (Linear Prediction Coding with Regular Pulse Excitation). Both operate at 13 kilobits.(but you take up more space on the network, so they can charge you more) - Talk-time is reduced with about 5%.
As battery life is a major goal for cell phone designers it is _extremely_ unlikely they would decide to "hide" some of it from the user and, thus, make their product less attractive than a competitors.
Mike Harding
AnswerID: 182716
Reply By: Member - Brian (Gold Coast) - Monday, Jul 10, 2006 at 16:34
Have seen this before..... and tried it!!!!!
It won't unlock most cars. The unlock code on most cars isn't triggered by sound.
112 IS an emergency number but it is my understanding that it only works if you have signal.
On my old Nokia it rebooted with that code but the battery level was exactly the same as it was before the reboot.
It's all urban myth.
Brian
AnswerID: 182738
Reply By: GaryInOz (Vic) - Monday, Jul 10, 2006 at 16:41
*******************DO NOT "TRY" NUMBER1 (112)*********************
This is an EMERGENCY number like 000 (which by law also has to work in Australia under the same conditions). 000/112 should be used in emergencies only, not "just testing". The staff at the other end get enough bogus calls as it is without unnecessarily cluttering up the system even more.
Most common "bogus call" is from business ppl that would normally go through a PABX at work to dial an international call , giving a 0 0011 ********** correctly when they are at work (normal 0 to get "out"), but by habit the use the same keystrokes at home leading to a false/unintended 000 call.
This was the reason why 008 calls went to 1800, 0055 went to 190*, when they did the increase from 9 digit phone numbers to 10 digits.
AnswerID: 182739
Follow Up By: MikeyS - Monday, Jul 10, 2006 at 17:21
Gary, aren't you an ambo, or have something to do with emergency services?
FollowupID: 439188
Follow Up By: GaryInOz (Vic) - Monday, Jul 10, 2006 at 18:06
I'm actually a Registered Nurse.
My Brother is in Telstra involved with the exchange engineering (senior level), including the routing of the 000 calls through the exchanges, and has had a bit to do with trying to eliminate the bogus calls from 000.
A lot of the carrier access numbers for O/S calls are also moving away from having a leading "00" for the same reason.
FollowupID: 439195
Reply By: Wazza - (Vic) - Monday, Jul 10, 2006 at 17:52
Number 2
Also Question 2
A few more Nokia Codes - I tried the "See Prive Number Code - seemes to work, yet to try it though!
Wazza
AnswerID: 182750
Follow Up By: Wazza - (Vic) - Monday, Jul 10, 2006 at 17:53
Private Number that is
FollowupID: 439192
Reply By: Mr Fawlty - Monday, Jul 10, 2006 at 19:47
No 2 is an Urban Myth....but credence is given in the way that it is worded but it is infact untrue. I even had a friend tell me she used it on her Beamer & it worked....But when I tried it the reason it worked was because she was standing next to the car when she tried it...Women, thank god they have bleep s otherwise they'd be useless...LOL sorry just joking.
AnswerID: 182776
Follow Up By: Des Lexic - Monday, Jul 10, 2006 at 20:07
Oh Mr Fawlty, you do like to live dangerously. You are right though. Not sorry, just LOL
FollowupID: 439227
Follow Up By: Mr Fawlty - Tuesday, Jul 11, 2006 at 10:18
Des, what would you expect from a man who has to endure Sibil 24/7......Danger is my middle name LOL LOL....
FollowupID: 439367
Follow Up By: Des Lexic - Tuesday, Jul 11, 2006 at 14:28
I know what you mean, I have just had my wife join an American Indian tribe and her new name is Three Horses. Nag Nag Nag for short
FollowupID: 439402
Reply By: Steve63 - Tuesday, Jul 11, 2006 at 12:56
Interesting thing about 1) is that 112 works on most phones even if the phone is locked.
Number 2) would have to be rubbish. A normal phone just does not transmit that sort of bandwidth. The only alarm I can think of that it just might have worked on was a very old alarm that used ultra sonic to avoid scanners.
Steve
AnswerID: 182920
