6.5lt Chev Convertion
Submitted: Monday, Jul 10, 2006 at 21:08
ThreadID: 35711 Views:7096 Replies:9 FollowUps:9
I currently own a GQ Patrol RX 2.8lt td with a corroded head and am considering a 6.5 lt Chev Diesel convertion. Can anyone offer me any info that may be usefull before I decide (pros-cons). Anything appretiated. Cheers
Reply By: Trekkie (Member - WA) - Monday, Jul 10, 2006 at 21:30
Try 3 different searches on this forum - Bilbo - Conversion and Chev
Should be enough reading to keep you busy for a while - Bilbo recently completed a conversion.
AnswerID: 182813
Reply By: ross - Monday, Jul 10, 2006 at 21:33
I think the $20000 + installation cost excessive considering the engines can be bought in the USA for a dime a dozen.
After riding in a 80 series and listening to the roar at highway speed I definately wouldnt want one for long drives.
I would be inclined to buy one already installed in a Patrol/Landcruiser and let someone else lose out big time on the resale value;)
AnswerID: 182816
Follow Up By: Joombi - Monday, Jul 10, 2006 at 22:02
I'd do the same, but, each to their own....
FollowupID: 439295
Follow Up By: TroopyTracker - Tuesday, Jul 11, 2006 at 17:38
Ross
Let me know when you find a troopy (less than 10 years old) converted with 6.5. I've been thinking about a coversion for a while and the resale is excellent otherwise I'd have done what you're saying. The few I have found have been asking a price that adds up to stock car plus conversion.
Matt
FollowupID: 439458
Reply By: Motherhen - Tuesday, Jul 11, 2006 at 00:27
Anyone looked into putting a Chev Duramax into a Patrol, and will it fit?
CHEV 6.6LT DURAMAX DIESEL- New Motor
Chev 6.6LT 2004 model Duramax 300HP Turbo Diesel comes with alloy heads, computer, direct injection, air alternator,air cond, starter, turbo, engine displacement 402CID (6599CC) Cost $12000 #190A. 12 months guarantee
CHEV 6.6LT DURAMAX DIESEL- Good used Motor.
Chev 6.6LT 2003 model Duramax 300HP Turbo Diesel comes with alloy heads, computer, power steer, direct injection, air conditioning, alternator, starter, turbo, engine displacement 402CID (6599CC) Cost $8000 #190. 6 months guarantee.
AnswerID: 182854
Follow Up By: TroopyTracker - Tuesday, Jul 11, 2006 at 17:39
G'day there,
Won't fit aparantly.
Matt
FollowupID: 439460
Follow Up By: Member - Pezza (QLD) - Sunday, Jul 16, 2006 at 17:13
Hi Motherhen,
Have a look at post 33338 & 32839, will answer your question.
Avagoodn
Pezza
FollowupID: 440407
Follow Up By: Motherhen - Sunday, Jul 16, 2006 at 17:23
Thanks Pezza - TroopyTracker sent me the content - i had missed it while i was away. Son still thinks he could fit it in! This is the one who puts bigger and bigger v8s in a hilux.
FollowupID: 440408
Reply By: Member - Vincent A M (NSW) - Tuesday, Jul 11, 2006 at 08:47
Remember the sound proofing due to the engine roar, even if your a little deaf
AnswerID: 182884
Reply By: adamj1300 - Tuesday, Jul 11, 2006 at 09:43
i remember reading about some dude was wanting to put a duramax in a patrol but the motor is to long?
AnswerID: 182897
Reply By: kiwicol - Tuesday, Jul 11, 2006 at 16:47
my understanding is the 2,8 has to lower diff ratio for the chev making them very uneconomical, the 4.2 diffs are the right ratio. col
AnswerID: 182957
Follow Up By: Exploder - Tuesday, Jul 11, 2006 at 21:33
They generally come with a rebuilt gearbox out of the 4.2 and rebuilt Diffs geared to your preference + the rebuilt Chevy all for $20,000 or something.
FollowupID: 439518
Follow Up By: Spike me - Thursday, Aug 03, 2006 at 19:16
BAAAAAAAAAAAAAAAAAAAAAAAA BAAAAAAAAAAAAAAAAAAAAAA
I hear you are a little Sheeeeeeeeeepish
FollowupID: 444109
Follow Up By: Member - Roachie (SA) - Thursday, Aug 03, 2006 at 19:38
Spike me...............
It'd be good if someone did!!!!!!!!!!!!!!!!!!!! hahahaha;-)))
FollowupID: 444114
Reply By: mechpete - Friday, Jul 14, 2006 at 21:22
Hi jasontaggs,
don,t waste ya money ,
I,ve been servicing a fleet of GMC ambulances for several yrs and it has cost a bloody fortune to keep them on the road . The common problems are porous blocks some cyl head problems and heaps of injector pump problems ,black box on the pump ( fuel solenoid driver ) by the dozens at $675 plus labour premature water pump leaks,at numerous places on the engine oil leaks , and so on
the motors are a piece of bleep , they also use oil ,unlike a jap engine
cheers mechpete.
AnswerID: 183545
Follow Up By: Peter 2 - Sunday, Jul 16, 2006 at 15:00
If you do a search on the diesel page you can get a list of the serial numbers for the crook blocks, they were only made for a few years, before and after are ok.
they also usually only give trouble when used in a turbo motor or a NA that has been overheated.
My 6.2 uses less oil than the 1hz in the troopy ever did.
there are also cures for the fsd overheating by remote mounting. Most conversions also use a mechanical pump not the electronic one so no fsd problem.
Stanadyne injection pumps are very reliable, in fact more so than Tojo ones especially if fitted with the upgraded internals as most conversions do.
FollowupID: 440392
Reply By: mechpete - Sunday, Jul 16, 2006 at 16:33
Hi Peter2
FYI the prous blocks failed at no particular build date ours were from 97/2004
the remote mounting of the FSDdoes not fix the problem we trialed 70 out 135 vehicles and it made no improvement ,after a lengthy evaluation of the vehicles with the help of a company called VDA and heat chamber testing the coolest part of the engine bay is the pump because the fuel flowing through it acts as a cooling to the FSD we have piles of figures to validate it .
the engine swap into a vehicle using a mechanical pump is not roadworthy if the vehicle was manufactured to cmply with emission control regs as according to the laws the engine has to meet the same regs as the vehicle was built to comply with
cheers mechpete. PS what you read on the internet about these engines is not true 12 yrs of figures don,t ly .
AnswerID: 183773
Reply By: Member - Pezza (QLD) - Sunday, Jul 16, 2006 at 17:18
Hi Jason,
Have a look at posts 33338 & 32839, should be a good start for you.
If you decide to go ahead with it have look in the trader section of this site, you will find a gearbox I'm selling to suit that conversion perfectly ( it's what I originally bought it for ) and much cheaper than a conversion mob will charge you.
Avagoodn
Pezza
AnswerID: 183785
