Chemical Loo question
Submitted: Wednesday, Jul 12, 2006 at 10:16
ThreadID: 35762 Views:2218 Replies:4 FollowUps:8
How long does the chemical in the bottom tank last? What I am getting at is that if its only been used a couple of times is it ok to leave it for a few weeks and use again or should it be emptied when stored for more than a few days?
Reply By: Member - Stephen M (NSW) - Wednesday, Jul 12, 2006 at 11:33
Hi there Brew69, I always empty mine when I'v finished with it, unless I'm using it on a daily basis, then it will need emptying any way as it fills up. I dont want to take a risk of sh@t floating around in the back of my hilux or the camper trailer for that matter, just incase it sprung a leak, for the sake of a couple of $$ for the green crap that you put in the bottom tank, the rinse tank with the nice pink smelly stuff I will leave in that, as if it leaks every thing will be nice and deoderised, maybe a tad wet, If I have to refill the toilet on our last day of a trip and I know it will be a straight trip home I will only fill the flush tank about a quarter so Im not wasting as much deoderiser and water, then when I get home I give the whole thing a good wash out leaving the vents and so forth open so it will air out then I store away till next time. I have never had a problem with any smells in any way by doing it this way. As far as how long it would last in the tank I dont know but I dont want that crap sitting around as its cancer causing, full of formaldahyde I even wear plastic gloves when handling this stuff, Regards Steve M
AnswerID: 183121
Follow Up By: Member - JohnR (Vic)&Moses - Wednesday, Jul 12, 2006 at 14:30
Stephen, I have always been with you on the potential spillage so right from the start I containerised it. It sits in it's own box with the chemical spares too, toilet paper in a plastic bag and hand wipes. Any spillage will be minimised.
Did hear years ago about the guy who had his portapotty on the roof bars and the top came off spilling the contents over the car. Was it an outback or urban myth?
FollowupID: 439690
Reply By: Peter McG (Member, Melbourne) - Wednesday, Jul 12, 2006 at 11:37
Brew
We changed this year to using the new environmentally friendly stuff that comes from a company in Brisbane. It works really well and can stay in the loo long term. We picked it up at the Wandin show. If you're interested, I'll check on the name tonight.
AnswerID: 183122
Follow Up By: Dave from P7OFFROAD Accredited Driver Training - Wednesday, Jul 12, 2006 at 12:35
I think you may be talking about BioMagic... Same chemical for top and bottom tanks. Good stuff
FollowupID: 439668
Follow Up By: Peter McG (Member, Melbourne) - Wednesday, Jul 12, 2006 at 12:39
Correct. Works well, no smell and enviro friendly.
FollowupID: 439671
Follow Up By: Peter McG (Member, Melbourne) - Wednesday, Jul 12, 2006 at 12:41
Take a look at:
www.biomagic.com.au/
FollowupID: 439672
Follow Up By: Brew69(SA) - Wednesday, Jul 12, 2006 at 20:34
Cheers will give it a go.
FollowupID: 439749
Follow Up By: Motherhen - Wednesday, Jul 12, 2006 at 23:43
You need to follow their instructions and cleanse the tank of any chemical residues before using bio-magic. Some people reeckon it is wonderful and some say it is not as good as the chemical. Main advantage, it is envorinmentally safe to empty it anywhere (but don't make it obvious as others seeing you don't know it is chemical free), without harming the environment. We've yet to make the change, but generally use the shovel not the chemical anyway.
FollowupID: 439775
Reply By: Pajman Pete (SA) - Wednesday, Jul 12, 2006 at 12:21
We make our own mix from a recipe that was posted on here. Answer number 3. About 100ml in the bottom tank and a splash in the top.
We always empty as soon as we get home, give it a good hose out an leave all hatches open to air it.
AnswerID: 183132
Follow Up By: Bomber2849 - Wednesday, Jul 12, 2006 at 20:21
If you are using a home made recipe using Pine-O-Clean it shouldn't be emptied into a septic system. Kills the "good" germs and wrecks the septic system.
FollowupID: 439747
Reply By: Truckster (Vic) - Thursday, Jul 13, 2006 at 12:14
sounds like a load of bleep to me.
AnswerID: 183321
Follow Up By: PatNav - Thursday, Jul 20, 2006 at 21:35
i agree Truckster nothing better than a good sh@it in the bush
FollowupID: 441265
