Jayco Rims
Submitted: Wednesday, Jul 12, 2006 at 15:10
ThreadID: 35768 Views:3138 Replies:4 FollowUps:3
Hi All,
used to have a coromal which when you took the wheels off and put the rims on went underneath the garage doors, have now got a Jayco managed to get a couple of Camry rims which fit but the van wont go under for about 10 mm GRRRRRR!!!
would it be possible to get a 13'' rim {5 stud } that would fit the jayco ? and would that work ? any info appreciated,
regards,
Reply By: ZUKSCOOTERX90(QLD-MEMBER) - Wednesday, Jul 12, 2006 at 17:38
G'day Dave ,i suppose you have already tried with some air out of the tyres.
Bob.
AnswerID: 183184
Follow Up By: Dave Thomson - Thursday, Jul 13, 2006 at 14:36
Hi Bob,
yes mate these are with rims only.............
FollowupID: 439895
Reply By: Member - Vincent A M (NSW) - Wednesday, Jul 12, 2006 at 18:05
what wheel pattern is it
you will find most boat trailer shops & tyre shops have most stud patterns with all different size rims 10" 12" 13'' & so on with all diferent offsets
AnswerID: 183196
Follow Up By: Dave Thomson - Thursday, Jul 13, 2006 at 14:41
Thanks for that Vincent, I might as well ask when I go in but what I was wondering is would that be too low ? need advice I think,
anyhow,
thanks for the input guys,
FollowupID: 439898
Reply By: Pajman Pete (SA) - Thursday, Jul 13, 2006 at 08:23
My Dad had the same problem with his Troll when the canopy was on. To put it away he just loaded up 6 drums of water which dropped it enough to fit through. For 10mm some extra weight might just do it.
Pete
AnswerID: 183284
Follow Up By: Dave Thomson - Thursday, Jul 13, 2006 at 14:39
Hi Pete,
yes done that too, the problem is theres a "ridge" in the centre of the van roof that comes to a point and its that bit that wont let me through,
regards,
FollowupID: 439897
Reply By: disco1942 - Thursday, Jul 13, 2006 at 15:56
If you take a cutting torch to the rims and narrow then down thus removing the flanges will that lower it enough?
I have also seen storage wheels that look the weights from off a set of weight lifters bar bells with stud holes. A friend purchased a pair of these for his Jayco but the ends of the U-bolts sat on the ground and left the wheels spinning in the breeze.
AnswerID: 183352
