Synthetic oils.
Submitted: Wednesday, Jul 12, 2006 at 20:25
ThreadID: 35781 Views:2326 Replies:4 FollowUps:2
Hi.
Have been using mobil I 5w- 50 synthetic oil in our subaru car, and when checking the oil level, after having done say a 5hr run, have found the level has increased. The motor is in tip top order, low ks etc just wondering does this stuff expand, build up or whatever??. Leave the vechicle sit for a day and it reads correct level, noticed it a few times, anyone had this happen? apart from a odvious overfill.
Regards Axle.
Reply By: Notso - Wednesday, Jul 12, 2006 at 20:53
I wonder if there is a little vacuum forming in the dipstick tube by sealing off at the top and drawing oil up the dipstick tube, I suspect that happens with my Nissan 3.00.
AnswerID: 183229
Follow Up By: Member - Axle - Wednesday, Jul 12, 2006 at 21:04
Notso might have something there! subaru have a o ring at the top of the dipstick to seal it in the tube , .
Axle.
FollowupID: 439753
Reply By: Chaz - Wednesday, Jul 12, 2006 at 22:58
Hi Axle,
Like every thing else, I would imagine that it expands when it's hot. Thats why you always check your auto trans fluid when it's hot, and maintain the correct level in heat because the level is criticle in a transmission, but not so criticle in an engine. Perhaps synthetic oil expands more than mineral oils.
Chaz
AnswerID: 183254
Reply By: Member - Oldplodder (QLD) - Thursday, Jul 13, 2006 at 07:40
How much of an increase - 1mm , 5mm?
Have had it happen on a worn engine with petrol getting in the sump, but yours is not worn.
You would think that if the first check was when cold, and the 2nd check was when hot, that the hot reading would be lower due to the oil moving to the heads while running. Especially being a horizontal boxer motor. How well do the heads drain back to the sump? Is there a build up of oil in the heads when cold?
What does the manual recommend? Check when cold or hot?
You did wipe the dip stick before dipping and taking the reading both times?
Silly question I know, but it does make a difference after some oil surge.
5 hours should be long enough to get the engine hot to evaporate off any water and petrol in the oil too.
AnswerID: 183273
Follow Up By: Member - Axle - Thursday, Jul 13, 2006 at 17:43
Mate its been all over the place really! did a run up to orange in the central west about 5hrs from hear. checked it cold the next morning & it was 20mm over, wiped and checked again twice and it was under by 5mm. left it till i got home, the car stayed in the garage for two days after and i checked it again it was spot on the full mark!!. So its a bit wierd?
Axle
FollowupID: 439947
Reply By: Member - Kevin R (QLD) - Thursday, Jul 13, 2006 at 08:36
Hi Axle,
Dont know if this is a cause but I have a subaru 3.0RB and was told by dealer the correct mobil synthetic was the new one in the gold container which I think from memory is 10w30. Of course it more expensive than the other.
Kevin
AnswerID: 183286
