Fungus in Diesel Tanks?
Submitted: Friday, Jul 14, 2006 at 10:15
phillip owen
Just wondering if anyone has heard of a fungus (or something similar) that can get into and grow in diesel fuel tanks if the
tank is not filled frequently?
I have heard that this can happen if the
tank is not filled all that often and this fungus can then clog up filters, fuel lines and pumps leading to expensive cleaning bills?
Reply By: hl - Friday, Jul 14, 2006 at 10:46
Hi.
Yes, is a
well non problem. Algae will grow in diesel. Can be prevented with certain additives.
183469
Reply By: MAVERICK(WA) - Friday, Jul 14, 2006 at 10:58
and just wait until the problem starts getting into the 'new' common rail diesels now on offer. those poor little puegeots and golfs and astras and others won't know what has hit them. pick up the additive from any distributor and use the correct dose for your
tank size. if you already have it then the only real way to fix it is to drain and physically remove the brown muck from the
tank - once you have started to dose the
tank you need to continue. there was a filter system called 'de-bug' but i'm not sure if that is still available. as much as it was a mystery i was once changing filters every 10hrs and after shovelling out the tanks (not a 4wd) and fitting these filters no problem again - mind you i was also 'kill dosing' every fill. and don't worry about the distributors as they will all tell you their fuel is clean - bull bleep . rgds
183470
Follow Up By: RosscoH - Friday, Jul 14, 2006 at 16:03
I Agree with you Maverick, clean diesel don't exist and I deliver fuel for a living, Because diesel is recycled back to the
tank all the time the warm diesel heats the whole
tank , as soon as it starts to cool condensation starts forming and then you have just the right climate for all the bugs to start growing, use a good additive and you should have no more trouble after the
tank is cleaned out, Make sure whatever additive you use that it says that it will Dissapate Moisture.
Cheers Rossco.
440108
Reply By: Kiwi Kia - Friday, Jul 14, 2006 at 12:02
As I understand the problem it you have to have some
water present for it to start to grow. So if you can avoids any condensation forming in your
tank you should have no problem. This is probably where the 'keep your
tank full' theory comes from as condensation forms from
water vapour in the air above the fuel.
183482
Reply By: hopscotch - Friday, Jul 14, 2006 at 12:36
The 'Bug' is normally Cladisporium Resinae which grows at the interface between the diesel and the
water which is usually present in fuel tanks. As stated above the
water comes mainly from condesation so keeping your
tank as full as possible is very beneficial. Most modern vehicles are fitted with very effective filters and there is usually sufficient space under the fuel intake point to ensure that it does not cause a problem unless the
water level rises considerably. There certainly are additives on the market which will 'kill' the bug. Check to see if your fuel
tank has a low point drain and if so you can regularly drop a litre to ensure that the
water is kept in check.
Kevin J
183485
Reply By: Leroy - Friday, Jul 14, 2006 at 13:28
yeh a futch will fix that problem....yeh I reckon....
leroy
183494
Follow Up By: BILL from Fitch Fuel Catalyst Australia Pty Ltd - Friday, Jul 14, 2006 at 18:35
HI Leroy.
Well said mate but it is FITCH at least ONE person has some brains on this
forum.
REgards BILLS
440143
Follow Up By: Member - Ian W (NSW) - Friday, Jul 14, 2006 at 19:50
Yeah! I second that and we know who it ain't.
Ian
440153
Follow Up By: Leroy - Friday, Jul 14, 2006 at 21:32
Ian,
Don't rain on my thunder! I don't get many compliments like that these days so let me bath in it for a few hours before you reply! .....oh....ok you weren't refering to me......
well that's ok then hehe ;-))
Leroy
440170
Reply By: Member - Roachie (SA) - Friday, Jul 14, 2006 at 15:23
check out
www.morison.com.au
183501
Reply By: phillip owen - Friday, Jul 14, 2006 at 16:32
Thanks for the info guys. I don't have any problems at the moment, only that I heard of this algae growing and wanted to ask others about it. If the
tank is filled up at each filling, would this more than likely stop the algae from growing?
183505
Follow Up By: Member - Roachie (SA) - Friday, Jul 14, 2006 at 18:18
Should do; plus the more you use the vehicle , the less likely you are to have an issue. EG: if you drive enough to say fill the tank/s every day, you wouldn't be allowing enough time for the algae to develop in all liklihood. More likely to occur when you leave a half empty
tank sitting for days/weeks at a time.
However, some blokes who have say a GU Patrol, tend to only use the main
tank most of the time, only filling the sub-
tank up when they go on a long trip. This could be a recipe for trouble.
Roachie
440140
Reply By: Member - Phil G (SA) - Friday, Jul 14, 2006 at 20:20
I don't bother with additives if I'm doing plenty of km. But if I'm just pottering around town, I keep the tanks full and use Chemtech which contains a biocide.
183534
Reply By: Eric Experience. - Friday, Jul 14, 2006 at 22:23
Philip
The hand book for the Mercedes and Pug diesels I own both say that any fuel additives used in these vehicles will void the warranty. They recomend draining the fuel filter on a regular basis. The only times I have seen this algi in vehicles is tractors that only get used once a year for harvesting. Eric
183558
